bike757 Posted March 8, 2009 Share Posted March 8, 2009 I just installed halo projection headlights on my 99 Civic LX. All lights work except for the halo lights. There are two red wires - where/what do they hook up to. Link to comment Share on other sites More sharing options...
airjordan223 Posted March 8, 2009 Share Posted March 8, 2009 the red is a power wire, black is ground. hook up the red wire to a power source, depending whenever you want them on, such as with your parking/running lights, or low beams, or all the time. Link to comment Share on other sites More sharing options...
Xeryon Posted March 8, 2009 Share Posted March 8, 2009 Best bet is to get a hold of a meter. Trace some wires from the headlight, parking lights, accessory lights or run your own wire to a new switch. Make sure to check the lines with the meter so you don't accidentally wire into something that is live even when the car is off. Splice it in. I wired mine so that when I had the key turned on they automatically turned on. Since I had removed the AC on my car I used the unconnected compressor constant wire. It held the right voltage and was live as soon as the key was moved into the accessory spot. Link to comment Share on other sites More sharing options...
BrIaN EG2 Posted March 8, 2009 Share Posted March 8, 2009 since they told you how to do it i wont waste my breathe saying something thats already been stated.. but i can almost garuntee those wires are to the halos in the headlights Link to comment Share on other sites More sharing options...
