sfranzo Posted February 27, 2009 Share Posted February 27, 2009 1997 accord noticed lot of water on rear carpet and rear seat. I cleaned out the rails thinking blocked tubes but they are clean. I need help how to remove the rear seat. thanks Link to comment Share on other sites More sharing options...
nnoossss Posted March 12, 2009 Share Posted March 12, 2009 1997 accord noticed lot of water on rear carpet and rear seat. I cleaned out the rails thinking blocked tubes but they are clean. I need help how to remove the rear seat. thanks so did like water leak on the seats or somethin. Its really hard to get water out of the rear seats but they make this stuff that is like foam which takes water out of it idk wat its called but ur gona have to look it up but it works my buddy had this prob and it took care of it. Link to comment Share on other sites More sharing options...
wannaBstuntin Posted March 12, 2009 Share Posted March 12, 2009 There are bolts. 10mm I think. Remove the cushion (bottom) first. I think there is a bolt that holds it down in the back (between the backs of the seats and the cushion itself, by the seatbelt) Then there are more bolts to take out the backs of the seats. If you fold them down, you should see. Link to comment Share on other sites More sharing options...
