mpearce1974 Posted November 9, 2008 Share Posted November 9, 2008 False. Agreed! I run and have run K&N in everything I own! Link to comment Share on other sites More sharing options...
mpearce1974 Posted November 9, 2008 Share Posted November 9, 2008 On a side note: I just replaced the plugs in the Sol after running 2 tanks with injector cleaner in them, and guess what! I found Autolites! >_< Replaced with good old NGK and my idle seemed a little better, and has a bit more pick-up!! (could be placebo effect but....) Also it didn't hel pthat when they put the new plugs in they were all only about finger tight! Link to comment Share on other sites More sharing options...
Mitchness Posted November 10, 2008 Share Posted November 10, 2008 As far as MSD goes, yes the MSD controller and coil are unnecessary on Hondas, but the 8.5 wires should work wonderfully. Hell, my regular old Napa Beld wires work just as well if not better than stock. They've lasted alot longer at least. Go with the MSD wires, IMO, unless you're on a budget then the stockers will work just fine too. Link to comment Share on other sites More sharing options...
