C92hatchX Posted November 3, 2008 Share Posted November 3, 2008 i can get two brand new snow tires for 20 bucks, but they are 185/65/r14 will they work?, and im aware that they are 14's and ill be having 13's on the back unless i can find other 14s, but itll raise up the front so i wont be plowing snow so i guess thats good, im only running them till winter is over Link to comment Share on other sites More sharing options...
Mitchness Posted November 3, 2008 Share Posted November 3, 2008 It'll look goofy as hell, but it shouldn't be a problem mechanically. Your handling will alter and most likely suffer for it though especially combining studded with studless. Link to comment Share on other sites More sharing options...
Xeryon Posted November 3, 2008 Share Posted November 3, 2008 You can not run studded in Ohio. 99% positive that they are just plain rubber winter tires Link to comment Share on other sites More sharing options...
Kastigir Posted November 3, 2008 Share Posted November 3, 2008 You can not run studded in Ohio. 99% positive that they are just plain rubber winter tires I believe you can run rubber studs. Link to comment Share on other sites More sharing options...
Xeryon Posted November 3, 2008 Share Posted November 3, 2008 Well, you are probably right on that. Never thought about it since I have never heard of anyone using anything other then metal studs. I still stand by his winter tires are probably normal tires with just a winter tread pattern. Link to comment Share on other sites More sharing options...
C92hatchX Posted November 3, 2008 Author Share Posted November 3, 2008 yea they are just rubber winter tires just the rim is a 14 the tire size is 185/65R14 Link to comment Share on other sites More sharing options...
Kastigir Posted November 3, 2008 Share Posted November 3, 2008 Unless you get tons of ice, which Ohio does not, then studs are fairly useless. A good set of winter rubber would be a good investment. Personally, I'd either change to 14s all around, or pick up some 13" winter tires. Honestly, unless you really suck at driving, all seasons will get you through most everything. Link to comment Share on other sites More sharing options...
Xeryon Posted November 3, 2008 Share Posted November 3, 2008 Kastigar, there is a MASSIVE difference between Cincy and the south Eire shore. I know, I grew up right on the lake in North-Central OH. In the Cleveland area they measure snow by the feet and the next day the temp is 45, the next they get another two feet of snow. The ice is ridiculous. Every single day you get the melt and refreeze for three months in a row. Totally blows. Do a comparison here: http://www.miata.net/garage/tirecalc.html Nice little applet that will tell you exactly what the difference between your current and the new tires are. You may be surprised... Link to comment Share on other sites More sharing options...
C92hatchX Posted November 3, 2008 Author Share Posted November 3, 2008 thats pretty cool and that is a big difer., but you guys dont think itll be too diferent?, im just going to use my two 13 inch snow tires on the back, or should i do vise versa Link to comment Share on other sites More sharing options...
