BJ223 Posted October 14, 2008 Share Posted October 14, 2008 where do these honda crx leak water, because i am trying to track down the water leaks in the back, it looks like the water comes in at the tail lights, but i would like to know if any one can suggest possible areas to as where water could be leaking in, so im not just taking apart the car in places that dont need to be taken apart. Link to comment Share on other sites More sharing options...
CRG7 Posted October 14, 2008 Share Posted October 14, 2008 which year? you could spray the rear with water to see where it is leaking. try checking the seals on the tails, make sure they tails are on tight, check the hatch seal... Link to comment Share on other sites More sharing options...
BJ223 Posted October 14, 2008 Author Share Posted October 14, 2008 which year? you could spray the rear with water to see where it is leaking. try checking the seals on the tails, make sure they tails are on tight, check the hatch seal... alright thanks, the car is a 91, and i also have a weird sqeaking noise from the back as well would you know what that is. Link to comment Share on other sites More sharing options...
elusiveshame Posted October 14, 2008 Share Posted October 14, 2008 CRX's are known to be squeeky, especially in the hatch area. Water leaks in from the top of the hatch, or at least on mine it did (the was the only place for me). Aside from that, check all your seals. Link to comment Share on other sites More sharing options...
Xeryon Posted October 14, 2008 Share Posted October 14, 2008 Mine isn't a CRX, but I leak from a split seal inside the fuel door indent on my sedan. Link to comment Share on other sites More sharing options...
