hondakid360 Posted July 18, 2008 Share Posted July 18, 2008 I was wondering if the alternator had to be in for the stock fan to work in a 87 crx. Not sure if the year matters on this question. Also, how much does the electric fan help to keep the engine cool? Link to comment Share on other sites More sharing options...
Tubbith Posted July 19, 2008 Share Posted July 19, 2008 Your going to need the Alt. to keep the car running.. not sure if you will need it for the fan or not though.. Link to comment Share on other sites More sharing options...
1CRX916 Posted August 8, 2008 Share Posted August 8, 2008 I was wondering if the alternator had to be in for the stock fan to work in a 87 crx. Not sure if the year matters on this question. Also, how much does the electric fan help to keep the engine cool? I replaced my radiator a while ago and it seems the fan never works but I'm running a opt. temp. I've changed my alternator a FEW times(not built like they use to be) and never had an effect on my fan. Which did you change?? the fan or alt, and onto what? Link to comment Share on other sites More sharing options...
mpearce1974 Posted August 8, 2008 Share Posted August 8, 2008 I replaced my radiator a while ago and it seems the fan never works but I'm running a opt. temp. I've changed my alternator a FEW times(not built like they use to be) and never had an effect on my fan. Which did you change?? the fan or alt, and onto what? Where are you getting your alternators from? Link to comment Share on other sites More sharing options...
coolcat467 Posted August 8, 2008 Share Posted August 8, 2008 I replaced my radiator a while ago and it seems the fan never works but I'm running a opt. temp. that means your radiator is working good the fan is there to help it when it needs help Link to comment Share on other sites More sharing options...
1CRX916 Posted August 8, 2008 Share Posted August 8, 2008 Where are you getting your alternators from? Apparently from a store(Krapan) that offers lifetime warranties for alternators and I know why!!! This is one of the reasons I stopped washing my engine. Pain in the but to hae to wrap it in plastic all the time!!! Link to comment Share on other sites More sharing options...
coolcat467 Posted August 8, 2008 Share Posted August 8, 2008 washing your engine casually should not cause alternators to go bad Link to comment Share on other sites More sharing options...
James Matteu Posted August 8, 2008 Share Posted August 8, 2008 You may want to look into replacing the wiring harness leading up to the alternator. I had numerous alternator problems on my 1987 CRX DX and changing the harness solved them all. Link to comment Share on other sites More sharing options...
