BrIaN EG2 Posted September 16, 2008 Share Posted September 16, 2008 That would be because the 1Gs are 6 bolts...tard. ROFL Link to comment Share on other sites More sharing options...
Hatch92 Posted September 17, 2008 Share Posted September 17, 2008 Lets get some people off of talk to do that. Lets get old man Steve to do a beachball pic with a Honda. LMAO. Crankwalk is for the 2G 7bolts, I havent heard of any 1G 7bolts ever crank walking. DSM's FTMFW!!! 7-bolts are only in 2G+ 4g63's and 7 bolt>6 bolt Link to comment Share on other sites More sharing options...
speed_demon Posted September 27, 2008 Share Posted September 27, 2008 That would be because the 1Gs are 6 bolts...tard. :chair: Umm, they are not all 6 bolts. 6 bolts were only done in the 90 - 92.5 model dsm's. They switched to the 7 bolts halfway through 92. So all of the 92.5 - 99 had the 7 bolt engine. Link to comment Share on other sites More sharing options...
Kastigir Posted September 27, 2008 Share Posted September 27, 2008 :chair: Umm, they are not all 6 bolts. 6 bolts were only done in the 90 - 92.5 model dsm's. They switched to the 7 bolts halfway through 92. So all of the 92.5 - 99 had the 7 bolt engine. Yes, which is something I've found out recently. 7 bolts still walk more frequently than 6 bolts. Link to comment Share on other sites More sharing options...
alex37211 Posted September 27, 2008 Share Posted September 27, 2008 I think the craptyness of the video / song shouldn't take from the joke itself. "DSM theme song" >>>"Do the crank walk" That's priceless. Link to comment Share on other sites More sharing options...
speed_demon Posted September 27, 2008 Share Posted September 27, 2008 Yes, which is something I've found out recently. 7 bolts still walk more frequently than 6 bolts. Yes, the 7 bolts do crankwalk more often than the 6 bolts. Although I have yet to hear if a 1G 7 bolt crankwalks, always heard of the 2nd gen 7 bolt crankwalking. Link to comment Share on other sites More sharing options...
Kastigir Posted September 27, 2008 Share Posted September 27, 2008 Taken from VFAQ A 'walking' crankshaft is a crankshaft that moves too much inside the engine. This is also known as excessive thrust bearing play. The movement is usually due to the crankshaft not fitting inside its bearings correctly. While not bad for the crankshaft, the movement can place excessive or uneven loads on the bearings, causing premature failures. Many 2G owners have suffered from walking crankshafts. It appears that Mitsubishi built many 2G engines using defective crankshafts, which were machined out of specification and are thus capable of moving around too much inside the block. All 2G model years appear to be affected to some degree. To fix this problem, Mitsubishi has designed several versions of matching crankshaft bearings. This allows the defective motor to retain the crankshaft, yet matches the bearings correctly so as to eliminate the excessive crankshaft movement. Matching the bearings in this manner is tricky and requires exact information about when the crankshaft was manufactured, which may be determined by color markings on the crankshaft itself. The 2G factory manual includes information on how to match crankshafts to bearings. 1G owners do not generally need to worry, as there are no chronic problems with crankwalk in per-1995 cars. However, it is possible for any engine to experience crankwalk if there is a problem with the crankshaft bearings. It has been reported that 'small rod' / 7-bolt flywheel motors (manufactured from later 1992 through 1994 on 1Gs) are more prone to crankwalk than 'big rod' / 6-bolt flywheel engines (manufactured from 1989 to early 1992). However, there can be no guarantees, since big block V8s and all other engines can also suffer from crankwalk. It can be difficult to tell if a particular car is experiencing crankwalk. Symptoms are usually indirect and difficult to diagnose until major damage occurs. Since the clutch places pressure on the crankshaft, many owners have reported clutch or shifting problems associated with the walking crank. Having the clutch 'stick' down on left-hand turns is often a telltale sign of crankwalk. Other symptoms include inconsistent engagement height, poor or rough engagement, difficulty shifting, ticking noises and varying pedal height or pressure. Another possibility is having the engine RPM decrease significantly when the clutch pedal is down. Another problem with crankwalk is that the crankshaft may move so much as to literally tear up and destroy the 2G crankshaft angle sensor. This problem usually manifests itself as a ticking noise coming from the timing belt area, as the sensor is literally and slowly ground away by the crankshaft. Any such noise should be investigated right away to prevent serious problems. Unfortunately, cranshaft angle sensor failure usually leads to a replacement sensor, rather than a replacement crankshaft, as mechanics fail to diagnose the underlying problem. 2G owners who have experienced premature failure of the crankshaft angle sensor should investigate the possibility of a walking crankshaft immediately. For more information, read this post by Paul Estavez, which describes the crank walk problem in detail. Also read Road Race Engineering's archive of posts that contains all of the Talon Digest posts about the walking crankshaft problem. Those who appreciate that a picture is worth a thousand words will appreciate the Crank Walk Photo Archive. Although 2G DSM owners have been anxiously awaiting a recall or TSB on the crankwalk problem, there is none as yet. According to Paul's second post on the subject, there may never be a TSB, although some members of DSM Canada are pushing for one in this thread on their discussion board. As a result, it is doubly important that affected 2G owners get their bearings (or blocks, if necessary) replaced before their warranty expires. This might be difficult for owners of aftermarket clutches, as dealerships often claim the aftermarket pressure plates are the cause of the problem. The consensus is that 7 bolt motors, are fatally flawed in their design. I checked my endplay last weekend, and it came out to .004". Tolerance is .0098" Link to comment Share on other sites More sharing options...
