ZCrxSiR Posted June 4, 2008 Share Posted June 4, 2008 Anyone Runnin A ZC? If so, What have you adjusted your Valves too? I know Intakes are between .006 and .009 and exhaust are .008 too .011. Mine are currently at 8 and 10 but there still noisy as hell but the car runs great! Was just wandering what worked well for others, or what different combinations have been tried that seemed to be an improvement for others Thanks In Advance For Your Feedback!! Link to comment Share on other sites More sharing options...
Kastigir Posted June 4, 2008 Share Posted June 4, 2008 Anyone Runnin A ZC? If so, What have you adjusted your Valves too? I know Intakes are between .006 and .009 and exhaust are .008 too .011. Mine are currently at 8 and 10 but there still noisy as hell but the car runs great! Was just wandering what worked well for others, or what different combinations have been tried that seemed to be an improvement for others Thanks In Advance For Your Feedback!! Check your oil. If they're within tolerances, then they're not the problem. Link to comment Share on other sites More sharing options...
ZCrxSiR Posted June 4, 2008 Author Share Posted June 4, 2008 Check your oil. If they're within tolerances, then they're not the problem. Oil Is Fine.... I thought of that a long time ago, but i wish that was the prob. thanks though! Link to comment Share on other sites More sharing options...
..SSR.. Posted June 4, 2008 Share Posted June 4, 2008 Check the rockers themselves. DOHC ZC/D16A1 and B18A/B18B/B20 use ball mounted rocker arms that are prone to wear. Link to comment Share on other sites More sharing options...
