2gboostedteg Posted April 8, 2008 Share Posted April 8, 2008 Ok so when my buddie is leaving work tonight he goes out and starts his car to let it warm up, everything feels fine. Once he gets in his car to leave he pushes the pedal in to put it in gear, the pedal goes in fine then he heres a poping sound and then no pedal well it would not come back up and would not go in any gear. Now if he shuts it off he can put it in gear and when he starts it up in gear the car starts to move foward. The car is a 90 teg so we compared his clutch cable and pedal assembly to mine to see if we could notice a difference on the outside of the trans and we noticed that his cable has alot more play than mine so tommorow we are gonna drop the trans to check the clutch and throwout bearing and what not but if anyone has any adivce or and sort of help or has experienced this before and has a solution it would be very helpful, thanks. Link to comment Share on other sites More sharing options...
Hatch92 Posted April 8, 2008 Share Posted April 8, 2008 tighten up the cable. you jst asaid it hjas more slack then yours. if that doesn't work then you have a bad clutch. Link to comment Share on other sites More sharing options...
Tubbith Posted April 8, 2008 Share Posted April 8, 2008 Agreeded.. take as much slack out of the cable as you can, if it doesnt work after that, then drop the tranny and check stuff out...(why do something you dont have to) Link to comment Share on other sites More sharing options...
Kastigir Posted April 9, 2008 Share Posted April 9, 2008 Ok so when my buddie is leaving work tonight he goes out and starts his car to let it warm up, everything feels fine. Once he gets in his car to leave he pushes the pedal in to put it in gear, the pedal goes in fine then he heres a poping sound and then no pedal well it would not come back up and would not go in any gear. Now if he shuts it off he can put it in gear and when he starts it up in gear the car starts to move foward. The car is a 90 teg so we compared his clutch cable and pedal assembly to mine to see if we could notice a difference on the outside of the trans and we noticed that his cable has alot more play than mine so tommorow we are gonna drop the trans to check the clutch and throwout bearing and what not but if anyone has any adivce or and sort of help or has experienced this before and has a solution it would be very helpful, thanks. Can't believe with what you've posted, nobody offered up the obvious. The clutch cable snapped. Link to comment Share on other sites More sharing options...
Tubbith Posted April 9, 2008 Share Posted April 9, 2008 Can't believe with what you've posted, nobody offered up the obvious. The clutch cable snapped. Pretty sure what i said would have led to the discovery of this issue... Link to comment Share on other sites More sharing options...
James Matteu Posted April 9, 2008 Share Posted April 9, 2008 Can't believe with what you've posted, nobody offered up the obvious. The clutch cable snapped. Link to comment Share on other sites More sharing options...
SIR_VTEC Posted April 18, 2008 Share Posted April 18, 2008 It could be that your clutch cylinders need replacing...but then again it could be a whole different story Link to comment Share on other sites More sharing options...
