thesparkleman Posted June 3, 2003 Share Posted June 3, 2003 I recently purchased a 1996 Honda Accord EX. It has a 4 speed auto transmission. When I start to accelerate it shifts into 2nd gear, but not before there is a vibration right before it shifts. I was told it could be the U-joints but I want to make sure that its not the transmission. Or could it be something else? Any help would be greatly appreciated. Link to comment Share on other sites More sharing options...
Dragongyrl18 Posted June 3, 2003 Share Posted June 3, 2003 Maybe the timing is off. But transmission can also be the problem. Thats my opinion Link to comment Share on other sites More sharing options...
ImportGirl82 Posted June 4, 2003 Share Posted June 4, 2003 check timeing and if that ok check ur tranny fliud...then check the cv joints...i belive u dont have u joints...hopefully ur boot is not torn...i heard it is expensive to fix..good luck let us know Link to comment Share on other sites More sharing options...
optional187 Posted June 4, 2003 Share Posted June 4, 2003 tranny fluid Link to comment Share on other sites More sharing options...
thesparkleman Posted June 4, 2003 Author Share Posted June 4, 2003 Thanks, I will try a few things out. Link to comment Share on other sites More sharing options...
TLontheDL Posted June 4, 2003 Share Posted June 4, 2003 you probably just need a tranny flush.. does it vibrate when you go at high speeds? Link to comment Share on other sites More sharing options...
thesparkleman Posted June 4, 2003 Author Share Posted June 4, 2003 It doesn't vibrate anytime except into 2nd gear and a bit going into third gear. It drives fine with no other odd noises or vibrations. Link to comment Share on other sites More sharing options...
qbanito420 Posted September 9, 2003 Share Posted September 9, 2003 i had the same problem with my 92 accord auto and my tranny was fried i ended up getting an h22 lsd auto tranny, but in a little while itll start slipping give it a good 6 mothes and ull need a tranny, im tellin u this from experience, cause it happened to me and i work at a transmission shop in miami so i kno what im talkin about Link to comment Share on other sites More sharing options...
TLontheDL Posted September 9, 2003 Share Posted September 9, 2003 have you changed your oil regularly? every 3k miles or so? Link to comment Share on other sites More sharing options...
