91hatchy Posted February 19, 2008 Share Posted February 19, 2008 when i did my b 16 swap in my 91 hatch i got my v tech wired up and i just hooked up just the (starter,wiring harness,headers) to see if it would crank over and it did but then when we hooked up the fuel lines it wouldnt crank any more i check the battery and it was charged but nothing but there was this black box for the ignition inside of the car making nosie and changed that out but still did the same thing can someone tell me some pointers to start it o and my gage cluster is not installed yet (i dont know if that will help) thanks Quote Link to comment Share on other sites More sharing options...
chris_agu28 Posted February 19, 2008 Share Posted February 19, 2008 Was there like a alarm in the car that you know of? maybe it cut off your iginiton switch. I had one on my del sol and took al that stuff out, It caused more problems then not having it in. Quote Link to comment Share on other sites More sharing options...
delsol209 Posted February 19, 2008 Share Posted February 19, 2008 maybe the starter took a crap you never know so i would go with trouble shooting everything lol Quote Link to comment Share on other sites More sharing options...
Hatch92 Posted February 20, 2008 Share Posted February 20, 2008 that little black box sounds like your starter solenoid. could be a bad wire on the starter. Quote Link to comment Share on other sites More sharing options...
..SSR.. Posted February 21, 2008 Share Posted February 21, 2008 Nothing inside the car controls ignition other than the ECU routed through the main relay. Hook jumper cables to the starter. That will tell you if its good or not. Quote Link to comment Share on other sites More sharing options...
Kegger Posted February 21, 2008 Share Posted February 21, 2008 ECU fuse. I think the little black box he is talking about is his main relay. It's clicking at him. Check that fuse and then try again. Quote Link to comment Share on other sites More sharing options...
