Repsol Posted February 13, 2008 Share Posted February 13, 2008 I unhooked the tube I had behind the passenger seat because it was taking up too much space. After I uninstalled, my head unite blinks "PROTECT". Does anybody know what this is or how to fix this problem? I hooked it back up to go to the trunk. Still did the same thing... Link to comment Share on other sites More sharing options...
delsol209 Posted February 13, 2008 Share Posted February 13, 2008 so you checked all your wiring? all your grounds are good? when taking off the monitor in the headunit did any wires touch? Link to comment Share on other sites More sharing options...
rocknskulls Posted February 13, 2008 Share Posted February 13, 2008 what exactly are we talking about? an amp?? if so check your fuses and if you turn the cd player off it should reset it and if your talking about the cd player theres a fuse on the back of it too Link to comment Share on other sites More sharing options...
chris_agu28 Posted February 13, 2008 Share Posted February 13, 2008 most likely if it isn't a fuse it is a ground or a power wire nothing too major. Just check the wiring and make sure the fuses are not blown. I pretty sure it is a ground wire. Link to comment Share on other sites More sharing options...
rocknskulls Posted February 13, 2008 Share Posted February 13, 2008 if it was s ground there would be nothing but since its getting power its got to be something else you have to have ground and power to be able to have power and for it to be saying protect it proves my point it has power Link to comment Share on other sites More sharing options...
Repsol Posted February 14, 2008 Author Share Posted February 14, 2008 Okay, I had a Pyle Bass Tube. Had a power wire running from the battery directly to the tube. I had a ground wire. I hooked my rear speaker wires to the tube. I unhooked everything because I need the space. I go to check if the radio works. Nothing, just blinks "PROTECT" I went to tuck the power wire in, and i touched the back metal piece that is under the plastic cover between the two rear speakers. I didn't touch any wires so I doubt I fried anything. Checked again, still was blinking. I hooked everything back up exactly how it was, but in the trunk so I could still have the space behind the seats. What do ya know, still blinks. Link to comment Share on other sites More sharing options...
rocknskulls Posted February 14, 2008 Share Posted February 14, 2008 the cd player its self ??? ill bet u fried a resistor or the fuse on the back of it Link to comment Share on other sites More sharing options...
speedfreek09 Posted February 23, 2008 Share Posted February 23, 2008 what type of deck is it, from what it sounds like you have a kenwood, and one of your speakers is either blown or one of the speaker wires is touching another speaker wire or is grounded. since you said you removed the bass tube and you had the rear speaker wires hooked to it, and not rca's that leans me to believe its one of those. btw its not a power issue becaust the deck is on. the deck will shut off the internal amp if its saying protect. it wouldn't come on at all if it had a blown fuse Link to comment Share on other sites More sharing options...
rocknskulls Posted February 23, 2008 Share Posted February 23, 2008 mine said protect when i blew a fuse on the back of the cd player but ya it could be you have wires touching reset the cd player afrter checking your wires and see if that does anything Link to comment Share on other sites More sharing options...
speedfreek09 Posted February 23, 2008 Share Posted February 23, 2008 he never said wat type of deck it was, it could be a bad fuse, but its alot more common to have a shorted speaker wire. the fuse on the back of the radio is constant and thats where it gets most of its power about 99 percent of the time the radio wont turn on at all Link to comment Share on other sites More sharing options...
