DelSolFreak Posted December 27, 2007 Share Posted December 27, 2007 anyone know when vtec is suppossed to engage on a b16a2? Quote Link to comment Share on other sites More sharing options...
solmeistro Posted December 27, 2007 Share Posted December 27, 2007 anyone know when vtec is suppossed to engage on a b16a2? i believe it's 5,500 rpm. someone correct me if i'm wrong though Quote Link to comment Share on other sites More sharing options...
CleanGSR Posted December 27, 2007 Share Posted December 27, 2007 Correct. 5500 on B16A2/A3 Quote Link to comment Share on other sites More sharing options...
DelSolFreak Posted December 28, 2007 Author Share Posted December 28, 2007 then what the hell is done to my car that i dont know about to make it engage at 4500? Quote Link to comment Share on other sites More sharing options...
cranny Posted December 28, 2007 Share Posted December 28, 2007 chipped ecu most likely. Quote Link to comment Share on other sites More sharing options...
DelSolFreak Posted December 28, 2007 Author Share Posted December 28, 2007 i've searched my car and check by the ecu( havent opened it though) and i havent seen a chip or any resemblance to 1. is it possible a have a honda s100? Quote Link to comment Share on other sites More sharing options...
IVhorsemenmotorsports Posted December 28, 2007 Share Posted December 28, 2007 i've searched my car and check by the ecu( havent opened it though) and i havent seen a chip or any resemblance to 1. is it possible a have a honda s100? you have to open it to see if it was chipped or if it has an s100 Quote Link to comment Share on other sites More sharing options...
CleanGSR Posted December 28, 2007 Share Posted December 28, 2007 Maybe you have a GSR ecu for some odd reason. P72 is a GSR ecu code. A B18C1 engages vtec at 4400-4500. Quote Link to comment Share on other sites More sharing options...
DelSolFreak Posted December 28, 2007 Author Share Posted December 28, 2007 no its a p30, but i have an obd2 serial port connector! idk man.....my car confuses the hell out of me sometimes! Quote Link to comment Share on other sites More sharing options...
IVhorsemenmotorsports Posted December 28, 2007 Share Posted December 28, 2007 no its a p30, but i have an obd2 serial port connector! idk man.....my car confuses the hell out of me sometimes! what year is the car? Quote Link to comment Share on other sites More sharing options...
DelSolFreak Posted December 29, 2007 Author Share Posted December 29, 2007 its a 97' Quote Link to comment Share on other sites More sharing options...
cranny Posted December 29, 2007 Share Posted December 29, 2007 what do you mean OBD2 serial port connector? that makes no sense to me. do you mean your ecu has a serial port in the case? Quote Link to comment Share on other sites More sharing options...
IVhorsemenmotorsports Posted December 29, 2007 Share Posted December 29, 2007 what do you mean OBD2 serial port connector? that makes no sense to me. do you mean your ecu has a serial port in the case? he probably means that he has the obd2 service port like all 96-newer cars have. But sometimes you can run in to a phase in car where it's a 95 but has an obd2 service port but has a 1 wire o2. sawthose in my college years Quote Link to comment Share on other sites More sharing options...
cranny Posted December 29, 2007 Share Posted December 29, 2007 yeah some of the early models of the newer setup. ive chipped an OBD1 PR3 before. same deal. its not confusing at all. your car is a 97 , its supposed to have a diagnostic port. if theres no jumper harness , that means its an OBD2 ecu , in which case it cannot be chipped , which makes your issue even more confusing , lol. take some pics or somin dude. Quote Link to comment Share on other sites More sharing options...
EH6TunerDaniel Posted December 29, 2007 Share Posted December 29, 2007 Mine hits a 5500 too, but when I had the automatic p30 in it it engaged at 4500. Quote Link to comment Share on other sites More sharing options...
DelSolFreak Posted December 29, 2007 Author Share Posted December 29, 2007 (edited) ok so deal..... (since i wont b able to get ics for while 4 u guys) 97' del sol 5 speed with factory b16a2, obd2 service port, no jumper harness, p30 ecu, 2 4-wire o2 sensors, vtec engages at 4500. i looked up the p30 and found it supposed to be on obd1 ecu. the reason im so confused is cause i know alot about a little when it comes to honda/ acura. i never liked hondas til i got my sol, now i love them! edit** just found out that my buddy has a digital camera. will get pics asap! btw.....thank for all the help you guys have given me since ive joined! Edited December 29, 2007 by DelSolFreak Quote Link to comment Share on other sites More sharing options...
cranny Posted December 29, 2007 Share Posted December 29, 2007 P30 ecu came in OBD2A del sols as well(96-97). i think you might have your answer up there , buddy said he ran an auto ecu and it engaged at 4500 , i see no other reason for this problem. was your car auto to manual converted? check the wiring under the hood over the tranny , see if theres any connectors not attached to anything. Quote Link to comment Share on other sites More sharing options...
DelSolFreak Posted December 30, 2007 Author Share Posted December 30, 2007 no. when i did a carfax on the car when i bought it, it said it was a 5 speed. but there is a 2 wire connector next to the ecu thats plugged into this little green thing that has 2 sockets in it but the green thing doesnt connect to anything Quote Link to comment Share on other sites More sharing options...
cranny Posted December 30, 2007 Share Posted December 30, 2007 that 2 pin connector should be blue. and the green rubber thing is just a holder. that 2 pin connector is for getting the codes from your car with the engine light. Quote Link to comment Share on other sites More sharing options...
DelSolFreak Posted December 30, 2007 Author Share Posted December 30, 2007 word thanks Quote Link to comment Share on other sites More sharing options...
