Pre-swap Tests??
alex37211
Posted
I got a wrecked 97 GSR to swap the motor into my civic.
I hooked up a radiator from a Toyota cresida to it so that I could start it. It looks ghetto as hell all wired in but it works.
I started it the other day.
The motor sounds good but I still want to be possitive that there isn't anything wrong that I can fix while the motor is out.
I'm going to do a compression check.
What should the compression be for each cylinder?
Also, are there any other tests that I can perform?
The motor has 150k miles on it already.
Will I need to change the water and oil pump?
Timing belt? Anything else?
Thanks.
Here's a pic of my ghetto-rigged radiator.
http://i68.photobucket.com/albums/i20/alex...eg/myteg016.jpg
Posted
definitely water pump, timing belt and tensioner.
who cares what it looks like? it worked for you to test it.
Posted
if it runs good. then i would do new timing belt, tensioner, water pump, all new fluids (coolant, & oil change). You could do a clutch kit and flywheel while you have the chance too.
Posted
Yes. I am planning on installing an ACT lightened flywheel and clutch. Is that a good choice for a NA daily driver? Or is there a better setup out there? Also, if I ever do decide to put a light turbo on it, Is there a flywheel / clutch setup that works better with turbo? Or does that not have anything to do with it?
Posted
ACT makes some good clutches and fly wheels. a street/strip clutch would be good for a DD and a lightly boosted set up
