preludakris Posted October 13, 2007 Share Posted October 13, 2007 awhile ago my clutch pedal starting getting weak and started grinding gears. so i changed the clutch and pedal got better . but still grinding . then i changed tranny and got better but still the same and pedal was weak again. so i changed slave cylinder and pedal is great but grinding still. i took it to a shop and they said ti was in the clutch . it grinds in neutral when i rev up . and while driving . is it possible i got a wrong clutch with the right flywheel. need advice asap. ripped tranny out five times in two weeks. please help. Link to comment Share on other sites More sharing options...
Hatch92 Posted October 13, 2007 Share Posted October 13, 2007 throw out bearing? did you replace the bearing when you changed the clutch or did you jsut change the clutch plate? Link to comment Share on other sites More sharing options...
cranny Posted October 13, 2007 Share Posted October 13, 2007 is your clutch fluid full? is your slave cylinder weeping/leaking? your master? Link to comment Share on other sites More sharing options...
preludakris Posted October 15, 2007 Author Share Posted October 15, 2007 i changed throw out bearing and switched the clutch back to stock just in case it was the wrong one. now it is a little easier to shift but only when rpms are under 4 g's and grinds while clutch is half way down.>_< Link to comment Share on other sites More sharing options...
preludakris Posted October 15, 2007 Author Share Posted October 15, 2007 i changed the throw out bearing and the fluid is full . would the flywheel cause a problem like this Link to comment Share on other sites More sharing options...
cranny Posted October 15, 2007 Share Posted October 15, 2007 this grinds while clutch is half down is confusing me? you mean when sitting still or you trying to shift when only pushing clutch halfway? Link to comment Share on other sites More sharing options...
preludakris Posted October 21, 2007 Author Share Posted October 21, 2007 this grinds while clutch is half down is confusing me? you mean when sitting still or you trying to shift when only pushing clutch halfway? while moving and sitting still. where is the main shaft bearing Link to comment Share on other sites More sharing options...
Hatch92 Posted October 22, 2007 Share Posted October 22, 2007 are you trying to shift the gears when the clutch is pushed in only half way? or do you have the clutch pushed to the floor when you shift? Link to comment Share on other sites More sharing options...
preludakris Posted October 22, 2007 Author Share Posted October 22, 2007 are you trying to shift the gears when the clutch is pushed in only half way? or do you have the clutch pushed to the floor when you shift? while its on the floor Link to comment Share on other sites More sharing options...
88prelude Posted November 5, 2007 Share Posted November 5, 2007 try your 1st second third fourth and fifth gear syncronoid cause my eclipse did and still does the same thing...when the clutch pedal is to th floor and i shift the clutch still grinds Link to comment Share on other sites More sharing options...
