SiR REX Posted September 11, 2007 Share Posted September 11, 2007 i have a 90 crx si..with 200,000+ miles on it.. it will start up just fine drive fine for about 20 minues then the check engine light will come on then a few minutes later it will just die..the dash lights will come on as if it were in the run posisition.. but then if i let it sit for a few hours it will start right back up... i have done a tune up on it changed the ignition coil and modual.. and it still does it.. and i have no clue what to do about it.. can anyone help me?? Link to comment Share on other sites More sharing options...
VR17 Posted September 11, 2007 Share Posted September 11, 2007 a loose battery connection? a wacky starter? older vehicles tend to have these kinds of problems.. Link to comment Share on other sites More sharing options...
tallhamer88 Posted September 12, 2007 Share Posted September 12, 2007 damn that sucks..my old car did that b4 it turned out i had a loose ground somewhere in the engine area check that Link to comment Share on other sites More sharing options...
cranny Posted September 12, 2007 Share Posted September 12, 2007 get the codes out of it , it will tell you what the problem is , lol. Link to comment Share on other sites More sharing options...
Kegger Posted September 12, 2007 Share Posted September 12, 2007 Alternator, battery, or bad grounds. Link to comment Share on other sites More sharing options...
Rick B. Posted September 12, 2007 Share Posted September 12, 2007 what about fuel pump? it almost sounds as if its stalling out. might want to check your fuel lines, injectors, pump, ect. Link to comment Share on other sites More sharing options...
SiR REX Posted September 12, 2007 Author Share Posted September 12, 2007 the codes read 1 then 6 and 1 i believe is the engine collant temp censor.. and that is flashing because its not connected.. and the other one is an o2 censor.. but the o2 censor wouldnt cause the car to just die like that would it??? if i make it somewhere without the car dyen and come to a stop.. if i try to reve the car up the idle fights against me and it will just bogg down and die.. Link to comment Share on other sites More sharing options...
Ben. Posted September 13, 2007 Share Posted September 13, 2007 If the lack of an o2 sensor would cause a vehicle such as a Honda to die a majority of the Honda populous would be immobile. LOL. Link to comment Share on other sites More sharing options...
Rick B. Posted September 13, 2007 Share Posted September 13, 2007 you should have your fuel pump checked, just in case. Link to comment Share on other sites More sharing options...
SiR REX Posted September 13, 2007 Author Share Posted September 13, 2007 well if it isnt the fuel pump what else could it be?? and how much is a new fuel pump for a crx neway? Link to comment Share on other sites More sharing options...
