Fras84 Posted August 25, 2007 Share Posted August 25, 2007 Does anyone know or has anyone tried to put an h22 in a civic hatch? I'm thinking about buying a 92 hatch and putting an h22 in it but I want to know if that is just a ridiculous idea or if it could possibly work... Link to comment Share on other sites More sharing options...
Hatch92 Posted August 25, 2007 Share Posted August 25, 2007 it's been done quite a few times. there is a little more work involved to put it in but it can be done. Link to comment Share on other sites More sharing options...
TLontheDL Posted August 26, 2007 Share Posted August 26, 2007 from what I heard 10 yrs ago, you loose the a/c option with that swap. Link to comment Share on other sites More sharing options...
93blacklx Posted August 31, 2007 Share Posted August 31, 2007 It can work just do some research before you start it Link to comment Share on other sites More sharing options...
xalexjx@yahoo.com Posted September 1, 2007 Share Posted September 1, 2007 http://www.hondaforums.com/index.php?showtopic=13646 Link to comment Share on other sites More sharing options...
cranny Posted September 2, 2007 Share Posted September 2, 2007 the biggest downfall with H22's in civics is the ground clearance , oil pan is close to the ground i find. the trannys are bigger , its a tight fit kinda but is a bolt in swap with mounts. make sure you get an OBD1 swap , and its pretty juch plug and play , wire VTEC is its not an Ex. Link to comment Share on other sites More sharing options...
