Important Questions.
Im ordering the B16 SiR II from Hmotorsonline.com and putting it in a 93 Civic Hatch SI
Wondering what custom work needs to be done. RHD motor, something bout splicing the wiring harness, or using a del sol harness, can anyone get into more detail about whats going to happen? i wanna know what im in for before i invest 3000 tomorrow afternoon. Thanks.
Send your stock ECU out to be socketed and get a chip from Kenji for a stock B16. That way you don't have to worry about the knock sensor. It'll cause more problems than its worth.
ph thats why honda(as well as all other car companies) uses knock sensors , cause they are more trouble than they are worth? anyways , all it is , is one wire dude. runs from ecu at passenger floor to knock sensor behind block , 4 feet long. piece of cake.
the car will run better and more reliable with the stock ecu.
