TrailMystic Posted April 1, 2007 Share Posted April 1, 2007 I've had my sol for 5 days now. I located an owner's manual on eBay for $2, but I don't have it yet. This forum has been great, albeit a little more "colorful" than my usual 4X4Wire forum. Tell me about my engine. It is stamped B16A3. The valve cover says it's a VTEC DOHC. The decal on the hood says engine family RHN1 6V JGEEA. I assume this is the original engine, but much about the past history of the car is a mystery. It supposedly only has 52,000, and it looks like it. I've read up on VTEC and understand how that works. What can all your collective wisdom tell me? Thanks, Pete . Link to comment Share on other sites More sharing options...
Ben. Posted April 1, 2007 Share Posted April 1, 2007 You've got probably one of the best Del Sol's on the market. Twin-cam, a lot quicker than it's SOHC counterparts obviously. Link to comment Share on other sites More sharing options...
krissi Posted April 1, 2007 Share Posted April 1, 2007 GOOGLE IS YOUR FRIEND VTEC Found in: 1994-1995 Honda Del Sol VTEC (EG) Displacement: 1595 cm³ Compression: 10.4:1 Power: 160 hp (119 kW) @ 7800 rpm & 111 ft·lbf (152 N·m) @ 7000 rpm Transmission: Y21 *courtacy of Google & http://en.wikipedia.org/wiki/Honda_B_engine#B16A3 http://www.jdmenginesamurai.com/engines/ho...ngine_b16a3.htm Honda B16A3 Engine JDM Displacement (cc): 1595 Power (bhp@rpm): 160 @ 7,600 rpm Torque (ft/lbs@rpm): 118 @ 7,500 rpm Compression Ratio: 10.8:1 Bore (mm): 81 Stroke (mm): 77.4 Cam Design: DOHC Valve Train VTEC Honda B16A3 Engines JDM The B16A3 was produced for the Honda Del Sol in the years 1994-1995 model. The B16A3 is one of the more popular used Honda engines sought out by tuners today. The trick is always finding a decent used JDM motor in great condition with good compression test results. Many JDM engine importers travel to Japan to test each engine before importing it back to North America. JDM engines sold in the secondary market are always a bit of a risk so it is important to deal with reputable JDM engine importer that has a long business history and provides warranty coverage and guarantees. If you want to see more used Honda engines return to JDM Engines. Link to comment Share on other sites More sharing options...
CRG7 Posted April 1, 2007 Share Posted April 1, 2007 I've had my sol for 5 days now. I located an owner's manual on eBay for $2, but I don't have it yet. This forum has been great, albeit a little more "colorful" than my usual 4X4Wire forum. Tell me about my engine. It is stamped B16A3. The valve cover says it's a VTEC DOHC. The decal on the hood says engine family RHN1 6V JGEEA. I assume this is the original engine, but much about the past history of the car is a mystery. It supposedly only has 52,000, and it looks like it. I've read up on VTEC and understand how that works. What can all your collective wisdom tell me? Thanks, Pete . Yes, it is the engine that is supposed to be in your car. It most likely is the original engine. The mileage may not be a mistake. Did you buy it from a dealership? I would think you might know more about it's history if you had purchased it from a personal seller... You could run a Carfax on it, if you haven't already. Link to comment Share on other sites More sharing options...
EH6TunerDaniel Posted April 1, 2007 Share Posted April 1, 2007 Honda B16A3 Engines JDMThe B16A3 was produced for the Honda Del Sol in the years 1994-1995 model. The B16A3 is one of the more popular used Honda engines sought out by tuners today. The trick is always finding a decent used JDM motor in great condition with good compression test results. Many JDM engine importers travel to Japan to test each engine before importing it back to North America. JDM engines sold in the secondary market are always a bit of a risk so it is important to deal with reputable JDM engine importer that has a long business history and provides warranty coverage and guarantees. If you want to see more used Honda engines return to JDM Engines. The B16A3 is USDM, not JDM. Link to comment Share on other sites More sharing options...
B00M3R Posted April 2, 2007 Share Posted April 2, 2007 You've got probably one of the best Del Sol's on the market. Twin-cam, a lot quicker than it's SOHC counterparts obviously. It is also a dual cam not a twin as the intake is obviously different then the exhaust cam. Link to comment Share on other sites More sharing options...
Ben. Posted April 2, 2007 Share Posted April 2, 2007 Um. Twin = Dual = Two. So, uh. Yea. Link to comment Share on other sites More sharing options...
