ArtyMillz Posted March 5, 2007 Share Posted March 5, 2007 i bought a 4-1 header and i didnt even thinkin about it untill now..... can i instal a 1 peice header with the engine in? like is there room to slide it in somehow? Link to comment Share on other sites More sharing options...
cranny Posted March 5, 2007 Share Posted March 5, 2007 get the car up high , and work it in from the bottom. Link to comment Share on other sites More sharing options...
CleanGSR Posted March 5, 2007 Share Posted March 5, 2007 Exactly. That's how I did it with the 4-1 one piece on my del sol. I was able to get it high enough with a floor jack, so you should be fine. Link to comment Share on other sites More sharing options...
ArtyMillz Posted March 5, 2007 Author Share Posted March 5, 2007 nicee i was worried lol but its good to hear its possible Link to comment Share on other sites More sharing options...
CRG7 Posted March 5, 2007 Share Posted March 5, 2007 If you have a B-series swap, you'll need to get a replacement for the crossmember, or it won't fit. Link to comment Share on other sites More sharing options...
ArtyMillz Posted March 6, 2007 Author Share Posted March 6, 2007 yea i do have a b series Link to comment Share on other sites More sharing options...
CRG7 Posted March 6, 2007 Share Posted March 6, 2007 yea i do have a b series You can bang out your crossmember, but I don't advise it. My brother did this in the past, and the entire bar ended up cracking. PasswordJDM sells a replacement bar that will work with it (around $300), or you can sell what you have and get a 4-2-1 which will have a better chance at clearing the crossmember. I'm in the process of deciding between the two options right now for my rex too. Link to comment Share on other sites More sharing options...
GsrCrx Posted March 6, 2007 Share Posted March 6, 2007 Whaaaa??? To put a header on a swapped car you need to take the crossmember out?!?! Link to comment Share on other sites More sharing options...
93b18c5FERIO Posted March 6, 2007 Share Posted March 6, 2007 the front crossmember is 2 bolts on the pass side and driver side, if you can get it in with the crossmember there then just take off the 4 bolts and put it up there. its not hard what so ever Link to comment Share on other sites More sharing options...
CRG7 Posted March 6, 2007 Share Posted March 6, 2007 There is not enough room in the engine bay of an EF after a b-series is in there for a 4-1 header. In order to run a 4-1 header on a b-series-swapped EF, you need to pretty much bang out the crossmember to accomodate the header, or swap it out for a thinner replacement. Link to comment Share on other sites More sharing options...
93b18c5FERIO Posted March 6, 2007 Share Posted March 6, 2007 There is not enough room in the engine bay of an EF after a b-series is in there for a 4-1 header. In order to run a 4-1 header on a b-series-swapped EF, you need to pretty much bang out the crossmember to accomodate the header, or swap it out for a thinner replacement. ok i see what you were sayin, yea i remember my buddy doin that also he just pounded in like a inch Link to comment Share on other sites More sharing options...
