CleanGSR Posted March 2, 2007 Share Posted March 2, 2007 Both the same width rim, does an offset of 40 stick out farther than a 42 or is it the other way around. My enkei's rub and they are 7" wide 40mm offset, so I'm trying to make sure if I need to get a 42, 45, or if I'm going the wrong direction alltogether. Link to comment Share on other sites More sharing options...
Pyrorocketeer Posted March 2, 2007 Share Posted March 2, 2007 42 would stick out more. Link to comment Share on other sites More sharing options...
CleanGSR Posted March 2, 2007 Author Share Posted March 2, 2007 No joke? Crap, so I need to look for about a 38 if I'm rubbing with a 40? Another question. WIll a 40 offset 7" wide rim or a 40 offset 6.5" rim sit out further. I'm assuming that if I get a 40mm 6.5" wide rim then it would sit back in the fender farther and fix the problem. Link to comment Share on other sites More sharing options...
Pyrorocketeer Posted March 2, 2007 Share Posted March 2, 2007 wait a sec.... i'm thinking about that Link to comment Share on other sites More sharing options...
Pyrorocketeer Posted March 2, 2007 Share Posted March 2, 2007 40 will stick out more... my bad Link to comment Share on other sites More sharing options...
CleanGSR Posted March 2, 2007 Author Share Posted March 2, 2007 Okay, so I do need to look for higher offset. WHat about the same offset in a smaller width rim? Like 40 offset on 6.5" rim and 7" rim. Would the 7" stick out farther or would they be the same? Link to comment Share on other sites More sharing options...
Pyrorocketeer Posted March 2, 2007 Share Posted March 2, 2007 the 6.5 with 40 offset would suck your tires in look here Link to comment Share on other sites More sharing options...
CleanGSR Posted March 2, 2007 Author Share Posted March 2, 2007 good link. thanks bro. Link to comment Share on other sites More sharing options...
Nancy Posted March 2, 2007 Share Posted March 2, 2007 +50 offset is stock for integras, nate. i personaly ran as low as +29 and those stuck out a little past the fender. the lower the offset, the more itll stick out. Link to comment Share on other sites More sharing options...
CleanGSR Posted March 2, 2007 Author Share Posted March 2, 2007 Yeah, the del sol wheels I'm running now are 45 offset and only 5.5" wide. My tires are tucking just a hair at my new ride height, so I need to make sure whatever new wheels I get don't stick out as much as the Enkei's. Link to comment Share on other sites More sharing options...
Nancy Posted March 2, 2007 Share Posted March 2, 2007 a 16" +43 are perfect for integras. the works i had are +43. Link to comment Share on other sites More sharing options...
Humphries Posted March 3, 2007 Share Posted March 3, 2007 my 15''s are 42 but i wanted 38 Link to comment Share on other sites More sharing options...
