Kicksome123 Posted January 15, 2007 Share Posted January 15, 2007 I have a knocking sound comming from under the hood, I know it has just about nothing to do with the engine because the engine still performs fine.... its just when I accelerate it does it, with regular throttle it starts around 3500 rpms and continues. I think its a bar or something that is rattleing against the engine. Im getting out tommorow and looking at it I just wanted some clues to maybe look for... I have a 99 ex if it helps any Link to comment Share on other sites More sharing options...
..SSR.. Posted January 15, 2007 Share Posted January 15, 2007 Does your oil have metal flakes in it? Link to comment Share on other sites More sharing options...
Kegger Posted January 15, 2007 Share Posted January 15, 2007 Does it sound like a midget banging on it with a hammer? Link to comment Share on other sites More sharing options...
Pyrorocketeer Posted January 15, 2007 Share Posted January 15, 2007 worn rod bearings knock under load. If its a rod bearing, you best stop driving it like...... 5 miles ago..... Link to comment Share on other sites More sharing options...
Kicksome123 Posted January 15, 2007 Author Share Posted January 15, 2007 I doubt I slung a rod if thats what your asking ssr, I seriously dont think its anything big. I think its more of a midget banging its more of a clicking than a banging Link to comment Share on other sites More sharing options...
Kegger Posted January 15, 2007 Share Posted January 15, 2007 Well then get the midget out from under the hood. But you might just need to change your oil. Link to comment Share on other sites More sharing options...
Kicksome123 Posted January 15, 2007 Author Share Posted January 15, 2007 Yall just give me some stuff to look at tommorow and I will just have to take a look... Link to comment Share on other sites More sharing options...
Kegger Posted January 15, 2007 Share Posted January 15, 2007 Start with the oil, then do a compression check, then pull the oil pan and look at the rod bearings and rods and cylinder walls. Link to comment Share on other sites More sharing options...
Kicksome123 Posted January 15, 2007 Author Share Posted January 15, 2007 I dont have anything to do a compression check, I have never taken my engine apart so...... yea Link to comment Share on other sites More sharing options...
Pyrorocketeer Posted January 15, 2007 Share Posted January 15, 2007 I doubt I slung a rod if thats what your asking ssr, I seriously dont think its anything big. I think its more of a midget banging its more of a clicking than a banging it will start as a tick, then progress to a click, then a hard knock, and pretty soon..... trust me...I know. Link to comment Share on other sites More sharing options...
Kicksome123 Posted January 15, 2007 Author Share Posted January 15, 2007 it will start as a tick, then progress to a click, then a hard knock, and pretty soon..... trust me...I know. I dont get it if its that..... I have never done anything to my engine for that to happen........... omgah if that happens I will be f*cked Link to comment Share on other sites More sharing options...
Kicksome123 Posted January 15, 2007 Author Share Posted January 15, 2007 I dont see how it could be that because the engine still performs fine... Link to comment Share on other sites More sharing options...
pinkb18crx Posted January 15, 2007 Share Posted January 15, 2007 pop your hood, listen closely to where its coming from, it could be top end thus a valve needing adjusted. If its bottom end more then likey its a rod bearing!! I dont know of random bars just knocking on a car for no reason either Link to comment Share on other sites More sharing options...
Kicksome123 Posted January 15, 2007 Author Share Posted January 15, 2007 pop your hood, listen closely to where its coming from, it could be top end thus a valve needing adjusted. If its bottom end more then likey its a rod bearing!! I dont know of random bars just knocking on a car for no reason either I diddnt ride it hard or anything last time I drove it... and I just started to drive it today and then about half way down the road it started doing it... Link to comment Share on other sites More sharing options...
Joe W Posted January 15, 2007 Share Posted January 15, 2007 I'd listen to them better to be safe than sorry man. Driven hard or not if it doesnt run it will not do you any good. Link to comment Share on other sites More sharing options...
Pyrorocketeer Posted January 15, 2007 Share Posted January 15, 2007 I dont get it if its that..... I have never done anything to my engine for that to happen........... omgah if that happens I will be f*cked Mine was stock.... mine was fine too, then all of a sudden, a tick. then I started to lose power, till BAM! destroyed my engine. one sign of it is a loss of oil pressure. have an oil pressure gauge in your car? Link to comment Share on other sites More sharing options...
Kicksome123 Posted January 15, 2007 Author Share Posted January 15, 2007 im pretty sure it does but I will check again tommorow, anyone out there does the stock ex have a fuel pressure gauge? Edit: ehhhh I dont think it doesnt.... How do I replace a rod bearing if it is bad??? Link to comment Share on other sites More sharing options...
Kicksome123 Posted January 15, 2007 Author Share Posted January 15, 2007 im pretty sure it does but I will check again tommorow, anyone out there does the stock ex have a fuel pressure gauge? Edit: ehhhh I dont think it doesnt.... How do I replace a rod bearing if it is bad??? Could I put the bottom end of my honda crx Si D15A3 with my D16Y8 head? Link to comment Share on other sites More sharing options...
Pyrorocketeer Posted January 15, 2007 Share Posted January 15, 2007 take out your engine. and rebuild everything. replace mains, and rod bearings. bearing failures are the worst, because you have to clean everything. oil gallies in your engine, crank gallies, and everything. anything that your oil touches has to be cleaned. oil coolers are now ruined. oil pressure gauge, not fuel pressure btw. Link to comment Share on other sites More sharing options...
Ben. Posted January 15, 2007 Share Posted January 15, 2007 IT'S A WOMBAT DUDE. IT GOT UNDER TEH HOOD AND SAID.. ALL UR PISTONS N RODS R BELONG TO ME Link to comment Share on other sites More sharing options...
Kicksome123 Posted January 15, 2007 Author Share Posted January 15, 2007 I cant use parts from my crx? God if I can this will cost so much money >.< Link to comment Share on other sites More sharing options...
Kicksome123 Posted January 15, 2007 Author Share Posted January 15, 2007 IT'S A WOMBAT DUDE. IT GOT UNDER TEH HOOD AND SAID.. ALL UR PISTONS N RODS R BELONG TO ME Please dont be joking around about this, I think this will cost me a sh*tload of money... Link to comment Share on other sites More sharing options...
Pyrorocketeer Posted January 15, 2007 Share Posted January 15, 2007 It will cost some, but not as much as it would if you keep running it like that.... set of mains and rod bearings max $200 new oil cooler max $100 lots of time. Link to comment Share on other sites More sharing options...
Kicksome123 Posted January 15, 2007 Author Share Posted January 15, 2007 where can I get the stuff, and are you positive this is whats wrong? Link to comment Share on other sites More sharing options...
Pyrorocketeer Posted January 15, 2007 Share Posted January 15, 2007 well you have to make sure that it isn't anything else first, like you were going to do. check oil pressure. check oil for shavings. drop oil pan check for play in bearings. may or may not be noticeable. .....can anyone add anything? Link to comment Share on other sites More sharing options...
