Headlights
BadasS2K
Posted
I have been having a problem with my headlights.
Moisture seems to get into the headlights and fogs up the glass causing them to look bad.
I have tried almost everything to keep them dry but nothing seems to work. Anyone have this same problem? A new set of headlights for an s2k is very expensive.
Posted
It's a bad seal.
Take them off, heat em up in the oven, remove the lense, scrape away the old sealant, but some new stuff, replace the lense, and voila. No leaks.
Posted
I had the same problem. All I did was remove the headlight and drill a couple of small holes in the bottom of it, let it air out and put it back on the car. Haven't had any problems since
  • 2 years later...
Posted
take them off, put some sealant around the edges.
