ImportGirl82 Posted February 9, 2003 Share Posted February 9, 2003 My hubby wants to know about the engine mounts for a b16a motor if they will mount up to where the orinal mount up ....and every preformance parts that will will go in a b16a motor, including piston and all the rings that need to go with it...etc...you can eeither email him or me or just do it hfere... Link to comment Share on other sites More sharing options...
S14Silvia Posted February 9, 2003 Share Posted February 9, 2003 this is for the 91 civic lx correct? if so then you need engine mounts to get the b16 in correctly. performance parts, ctr pistons & rings, stock rods should be fine, ctr cams, ctr intake manifold, jdm 4-1 header, 70 mm throttle body, type-r valvesprings & retainers. thats basically the jdm list of stuff, if you want more performance, then go with endyne rollerwave pistons, eagle rods, jun/crower/skunk2 stage 2/3 cams or toda spec c cams, jg edelbrock victor x intake manifold or skunk 2 intake manifold, kamikazi 4-1 header, spoon 70 mm throttle body, skunk2/jun/crower/toda valvetrain. you can do head work and bore the cylinders out to accomodate .25 oversized stock pistons or you can bump it up to a 1.8L and use the endyne pistons. Link to comment Share on other sites More sharing options...
PROFILES2000 Posted February 12, 2003 Share Posted February 12, 2003 they are good as a spare motor while the b18c1 is being rebuilt lol Link to comment Share on other sites More sharing options...
