motor swap
zbyrd
do yourself a favor , get an engine wiring harness for the car that engine would have came in. DOHC VTEC 1.6 car. be it civic Si , or del sol VTEC , even a GSR engine harness. and make sure the harness you get is OBD1. that way no conversion harness is needed. just tie a few wires in that stay in the car after harness is removed , like engine light , and power and ground , neutral safety , like i said in another post not long ago. just makes like easier and less problematic.
*AGREED*
and there's a bit of shavin of the front cross member if you want to put a header on that car rather than a stock exhaust manifold. make sure you grab the front spindles for the axles as well...unless if you want to get ur axles customed.
