GSR4Door13 Posted August 2, 2006 Share Posted August 2, 2006 OK, im getting an exhaust system made soon, and im trying to decide what size piping i should use. Im not sure if i want to use 2.25" piping or 2.5" piping. The canister im using has a 2.5" inlet diameter. i dont mind using 2.25" piping, but i plan on turbo charging the it in the future, and i dont want to get exhaust made again once i need a larger diameter kit. what i need to know is if the 2.5" piping will have to much backpresure or if it will be fine. Link to comment Share on other sites More sharing options...
CleanGSR Posted August 2, 2006 Share Posted August 2, 2006 If you turbo, you'll want a 3" exhaust, but a 3" exhaust would suck on a basically stock GSR. So either way you'll want to redo the exhaust once you turbo. 2.25" would be best for your current setup. Link to comment Share on other sites More sharing options...
xxscaxx Posted August 2, 2006 Share Posted August 2, 2006 +1 to what hung said. you could probably get away with 2.5 on a turbo setup (depending on mods) but 3" is better. if you are planning on turboing soon, just wait for the exhaust. Link to comment Share on other sites More sharing options...
