97blakkex Posted January 20, 2003 Share Posted January 20, 2003 Is It possible to replace my D16Z6 SOHC Ex engine with a B series engine? and if so what else do i need to replace... ANY knowledge is appreciated. thanks Link to comment Share on other sites More sharing options...
VR17 Posted January 26, 2003 Share Posted January 26, 2003 yea you can swappa B series engine in any honda..(it will fit) but if you want a DOHC Bseires head on top of a Dseires block. nope it wont fit(reasons??) well since some of the porting for oil and antifreeze dosent fit.. theres more reasons but try fitting a K20A on a D16Z6 LOL.. Link to comment Share on other sites More sharing options...
S14Silvia Posted February 1, 2003 Share Posted February 1, 2003 any b-series is a direct bolt in replacement for 92-01 civics and 94-01 tegs, if its before a 92 then you need motor mounts and a wireing diagram if you dont have vtec, but since you have a d16z6 sohc vtec engine all you need is motor, ecu, tranny, stock motor mounts, axles and shiftlinkage. possibley a wiring harness but i think your sohc vtec one will work with a little modification Link to comment Share on other sites More sharing options...
