import142 Posted May 29, 2006 Share Posted May 29, 2006 How do you take them off? Link to comment Share on other sites More sharing options...
xalexjx@yahoo.com Posted May 29, 2006 Share Posted May 29, 2006 in the back or the front? Link to comment Share on other sites More sharing options...
cranny Posted May 29, 2006 Share Posted May 29, 2006 if its the front , once you have upper balljoint seperated , only 2 nuts and bolts holding it on. back is easy bolt on spindle and bolt on chassis. Link to comment Share on other sites More sharing options...
xalexjx@yahoo.com Posted May 29, 2006 Share Posted May 29, 2006 well the way he said it was confusing, to pull the front upper ball joints off you need a fork tool, also when you take the two 17mm nuts off the inside of the engine bay you will nee a chisel and hammer or something to take the flatt plate thing off, as our front shock is in the way, make sure when you put new ones in you tighten everything really good. to take the ball joint out you need pliers to pull out the pin, 14mm wrench i believe, take the nut off, put the fork between the ball joint and inner link and tap it gently untill it pops off, easy to do, you just need time and patience, Link to comment Share on other sites More sharing options...
EH6TunerDaniel Posted May 29, 2006 Share Posted May 29, 2006 to take the ball joint out you need pliers to pull out the pin, 14mm wrench i believe, take the nut off, put the fork between the ball joint and inner link and tap it gently untill it pops off, easy to do, you just need time and patience, Its a 17 too, I just did this yesterday. Link to comment Share on other sites More sharing options...
import142 Posted May 29, 2006 Author Share Posted May 29, 2006 thx guys it helped hopefully i wont screw up or get impatiant. Link to comment Share on other sites More sharing options...
cranny Posted May 30, 2006 Share Posted May 30, 2006 never use a balljoint fork ever. youl destroy the rubbers. just take the crown nut off and smack it with a hammer on the spindle arm right under balljoint till it pops apart. thats how its done. Link to comment Share on other sites More sharing options...
xalexjx@yahoo.com Posted May 30, 2006 Share Posted May 30, 2006 well if your putting new ball joints in using a fork shouldnt be a problem Link to comment Share on other sites More sharing options...
EH6TunerDaniel Posted May 30, 2006 Share Posted May 30, 2006 Ive always used a fork and never messed anything up. Link to comment Share on other sites More sharing options...
