..SSR.. Posted May 20, 2006 Share Posted May 20, 2006 mainshaft 2nd gear is 2-3mm too high. hitting bottom of countershaft 3rd gear. Trying to figure out how to shim it. This sucks. Link to comment Share on other sites More sharing options...
Nancy Posted May 20, 2006 Share Posted May 20, 2006 tie a hair around it. Link to comment Share on other sites More sharing options...
..SSR.. Posted May 20, 2006 Author Share Posted May 20, 2006 Talking with the trans god right now. counted the teeth and the count is correct, but I might have a wrong gear in there. both are 30 count but the diameter is different for the 2 Link to comment Share on other sites More sharing options...
cranny Posted May 20, 2006 Share Posted May 20, 2006 try switching em around maybe. unless you did. your sayin its too big by 2-3 mm? take it to a machine shop have it planed on a CNC or whatever machine they got that will do it. gotta be different thickness to be causing this prolem but i cant see it so im not sure. Link to comment Share on other sites More sharing options...
..SSR.. Posted May 21, 2006 Author Share Posted May 21, 2006 Gears were correct. Clearance was fine after I removed the mainshaft washers. No way to shim it. Put in my stock 3rd for 4th so I can measure the VX 3rd. 4th is short, real short. Link to comment Share on other sites More sharing options...
