spinal Posted March 19, 2006 Share Posted March 19, 2006 OK! First I wanna say wassup and Thanks for all the Help and advice that you gave me in the past. Now I need your thoughts on my problem. I recently wrecked my 99 Si and before I put it in the shop I took off the plastic cover that goes inside your front wheel wells because they were dragging and i couldn't drive it home with them draggin. Make a Long story short.... Car got fixed, 4got to reinstall the wheel well covers and yesterday I drove in heavy rain with the covers off. On my way home my car started to sound really bad, loosin power and sound kinda like it was missin. When I got home I raised my hood to find my engine bay totally soaked and my filter drippin the water.. I need some advice on how or what to do to gettin this fixed besides putttin the covers back on. ( That I did already - lil late ) Thanks Again Guys 4 UR Advice!! Link to comment Share on other sites More sharing options...
90IntegraC1 Posted March 19, 2006 Share Posted March 19, 2006 you are fracked. water lock is bad. water in spark plugs is bad. water in distributer cap/rotor is bad. get a new car. Link to comment Share on other sites More sharing options...
Ben. Posted March 19, 2006 Share Posted March 19, 2006 you are fracked. water lock is bad. water in spark plugs is bad. water in distributer cap/rotor is bad. get a new car. I second that. Link to comment Share on other sites More sharing options...
spinal Posted March 19, 2006 Author Share Posted March 19, 2006 R U Serious??? Is it really that bad that I would have to get a new car??? No ways to fix it w/o rebuildin the engine or a swap??? Man my wifes gonna be PISSED!!! hahaha Link to comment Share on other sites More sharing options...
Ben. Posted March 19, 2006 Share Posted March 19, 2006 My uncle had one of those Econoline vans from Ford with the invincible 300-straight-6.. It's hard to kill one.. But he did. Waterlock PWNZ j00! Link to comment Share on other sites More sharing options...
xxscaxx Posted March 19, 2006 Share Posted March 19, 2006 yea your fracked. Link to comment Share on other sites More sharing options...
Verbal Killa Posted March 20, 2006 Share Posted March 20, 2006 Yep i 4th too that Link to comment Share on other sites More sharing options...
sohcVTEC-E Posted March 20, 2006 Share Posted March 20, 2006 5th. Swap that bitch out. Link to comment Share on other sites More sharing options...
HondasaurusEX Posted March 20, 2006 Share Posted March 20, 2006 You may not be totally fracked, just let it dry our put in a new filter, give the car a tune-up and see what happens.. Link to comment Share on other sites More sharing options...
h22cd5 Posted March 20, 2006 Share Posted March 20, 2006 You may not be totally fracked, just let it dry our put in a new filter, give the car a tune-up and see what happens.. i agree, let it sit for awhile to a nice breeze during the day, garage life it at night...basically baby the crap out of your car and then try replacing a few things to see if you can get her running again...if not, a swap would do the trick, best of luck Link to comment Share on other sites More sharing options...
cranny Posted March 20, 2006 Share Posted March 20, 2006 dont listen to them. dry your filter out and away you go dude. my 01 civic has no inner plastics. they dont use them anymore. you can look right through one side of car to the other with both front wheels off. thats through the wheel wells. change your motor cause of water jesus gimma a break. Link to comment Share on other sites More sharing options...
Double0EK Posted March 20, 2006 Share Posted March 20, 2006 If it still runs your most likely not HYDRO-LOCKED. Heres my advise. 1. Disconnect your Battery 2. Remove spark plug wires 3. Remove distributor cap 4. Check distributor cap for any water 5. If any water in distributor...REPLACE IT and the ROTOR 6. Since your at it replace spark plugs and spark plug wires. 7. Connect battery (remember always start with the positive side and connecting the negative last). Link to comment Share on other sites More sharing options...
spinal Posted March 25, 2006 Author Share Posted March 25, 2006 Thanks DoubleOEK... I did what you said and my cars back to normal.. Since then i went ahead and reinstalled the wheel well covers.... THX Again!!! Link to comment Share on other sites More sharing options...
99CiViCSi99 Posted March 26, 2006 Share Posted March 26, 2006 damn dude that sucks... time for a new car, lol Link to comment Share on other sites More sharing options...
mountaindewguy Posted March 26, 2006 Share Posted March 26, 2006 try the suggestions above to cure the problem if nothing works, and you've tried everything and its NOT WORKING, you fracked. swap it out. but do try the above suggestions, it might save you money in the long run. Link to comment Share on other sites More sharing options...
