shanehonda Posted February 6, 2006 Share Posted February 6, 2006 Hi I just put the springs and they are fairly new struts, and just put on 15s and I have a 1 1/2 inch wheel gape and when I go around a corner it rubs on the side walls on the rear tires and it is starting to make groves in the tires and I was talking with someone at work and the said that I need to get stiffer strutes and that would help and do you think that rolling the fender wells would help too? plz help Link to comment Share on other sites More sharing options...
xxscaxx Posted February 6, 2006 Share Posted February 6, 2006 Hi I just put the springs and they are fairly new struts, and just put on 15s and I have a 1 1/2 inch wheel gape and when I go around a corner it rubs on the side walls on the rear tires and it is starting to make groves in the tires and I was talking with someone at work and the said that I need to get stiffer strutes and that would help and do you think that rolling the fender wells would help too? plz help i really dont get what your saying. how much was the drop? if you have still 1 1/2 inch wheel gap left with 15s, you should definitly NOT be rubbing. your struts must be done. Link to comment Share on other sites More sharing options...
TLontheDL Posted February 8, 2006 Share Posted February 8, 2006 your tires might be too wide. what size tires are you using? Link to comment Share on other sites More sharing options...
cranny Posted February 8, 2006 Share Posted February 8, 2006 whats the 15's off of? i wouldnt say tired are too wide id say maybe hes usin like a volkswagon offset. id say his wheel offset is wrong if its not slack struts. Link to comment Share on other sites More sharing options...
DJB98LX Posted February 10, 2006 Share Posted February 10, 2006 I'd agree with the offest prob., but if you got fact. struts, that could be it too. Maybe both! Do yourself a favor, and don't roll your fenders yourself unless you really know what you're doing. My old (stupid) roomy wanted to use a Louisville to roll the fenders on his Miata. I helped him only because it was fun to see how wrong things could go, and they did. Wavy fenders, chipped paint, and not very rolled was the results, BUT, it's a Miata, and deserved it! Link to comment Share on other sites More sharing options...
shanehonda Posted February 13, 2006 Author Share Posted February 13, 2006 ya I have tein S. tech lowering springs and Motegi track lite 205 50 15's and it is on a 92 honda civic hb if that helps Link to comment Share on other sites More sharing options...
