jims88civicdx Posted February 1, 2006 Share Posted February 1, 2006 Just wondering if I would be able to swap an engine from an 94 civic si (D16Z6 engine) into my 88 civic DX which currently has a D15B2 engine.. what would be involved.. can i keep my current transmission(cable clutch setup) and bolt it on or do i have to go with the hydraulic one from the 94 setup.. would the motor mounts line up up or would i need to fabricate something up? as for wiring, would i be able to keep my old wiring and add some additional wiring.. or would i need to replace it all? Whats all involved? has anyone done this? if you have done this, can you list what i need to make the swap? any other ideas? and is the D16Z6 a VTEC engine? any input would be great Thanks, Jim Link to comment Share on other sites More sharing options...
jims88civicdx Posted February 1, 2006 Author Share Posted February 1, 2006 double post.. mods pls delete one.. thanks Link to comment Share on other sites More sharing options...
..SSR.. Posted February 1, 2006 Share Posted February 1, 2006 Mounts work. Use your stock trans. You need a $340 harness. Link to comment Share on other sites More sharing options...
jims88civicdx Posted February 1, 2006 Author Share Posted February 1, 2006 Mounts work. Use your stock trans. You need a $340 harness. could you eliborate on this $340 harness? where to get it from .. scrap yard? car? performance part shop? can you splice? so the mounts match and the tranny will bolt right up? will i be needing a different clutch or flywheel? Link to comment Share on other sites More sharing options...
jims88civicdx Posted February 3, 2006 Author Share Posted February 3, 2006 anybody able to eliborate? Link to comment Share on other sites More sharing options...
xalexjx@yahoo.com Posted February 3, 2006 Share Posted February 3, 2006 pm him,,he knows everything youll need...it should all bolt up fine all you need is an obd conversion as those engines are from diff gens Link to comment Share on other sites More sharing options...
