Guest that1chrisguy Posted December 2, 2002 Share Posted December 2, 2002 Alrighty, My friend is hooking me up with some coilovers for my 88 hatchback. Now, I ask, is this a pretty simple job for me to do? I cant afford to have some pro put it in.. Link to comment Share on other sites More sharing options...
optional187 Posted December 2, 2002 Share Posted December 2, 2002 ever changed a tire? Link to comment Share on other sites More sharing options...
WRX Driver03 Posted December 2, 2002 Share Posted December 2, 2002 I've put springs and coilovers on before, the first time was a bitch but after that it is a piece of cake. Yeah you gotta take all the tires off, take out the struts with the springs still on. Be sure to use a spring compressor to get the springs off or you could get hurt. Then just do the reverse order of directions I just gave. Sounds easy with the directions I gave, right??? Ha, have fun man it will be an experience. Link to comment Share on other sites More sharing options...
JBEX Posted December 6, 2002 Share Posted December 6, 2002 It can't be that hard if you got the right tools, man. Link to comment Share on other sites More sharing options...
EGRacer Posted December 6, 2002 Share Posted December 6, 2002 what kind he getting ya. u hopin for some teins cause i know i am Link to comment Share on other sites More sharing options...
Guest that1chrisguy Posted December 11, 2002 Share Posted December 11, 2002 Neuspeed Link to comment Share on other sites More sharing options...
EGRacer Posted December 11, 2002 Share Posted December 11, 2002 not a bad choice. they should suit u just fine Link to comment Share on other sites More sharing options...
TLontheDL Posted December 11, 2002 Share Posted December 11, 2002 neuspeed coilovers? wow.. i didnt know they made those.. i heard negative comments on neuspeed springs b/c they're too bouncy but i dont know about their coils. how much are those anyway? why dont you save up and get some teins or jic? well, just lets us know! Link to comment Share on other sites More sharing options...
EGRacer Posted December 11, 2002 Share Posted December 11, 2002 yea their springs are pretty crapty. but their coils are very nice i give em a 8 out of 10 Link to comment Share on other sites More sharing options...
rtperformance Posted December 17, 2002 Share Posted December 17, 2002 Its not to hard of job your going to need a jack, spring compressor and a few common wrenches metric of course. sometimes the lower bolts like to stick to the stock bushings in the back so you might want to plan on buying new bushings you are also going to have to cut the stock bump stop usually just in half you might want to take off more depending upon how low you want to go put the new coilovers on make sure you have them all set at the same height and you should be good to go also have you considered buying an alignment correction kit if you dont youll wear your tires out fast Link to comment Share on other sites More sharing options...
