Speedy88 Posted September 14, 2005 Share Posted September 14, 2005 hey i have a 91 civic dx 5spd, iv tryed 3 rpm tacs and they all read up to 3rpm then the rev limiter clicks in any ideas? Link to comment Share on other sites More sharing options...
..SSR.. Posted September 14, 2005 Share Posted September 14, 2005 Cluster doesn't control rev limit, ECU does. Link to comment Share on other sites More sharing options...
XScarAudio Posted September 14, 2005 Share Posted September 14, 2005 i believe that is the rev limiter in neutral on all older hondas to prevent damage. When in gear / under load, it should be about 200-400 rpms past what it reads. For example, my EX rev limiter is 7200 rmp, but the tach shows just about 6900-7000. Link to comment Share on other sites More sharing options...
..SSR.. Posted September 14, 2005 Share Posted September 14, 2005 All Honda tach's are usually over by a couple hundred RPM. Link to comment Share on other sites More sharing options...
x_outlaw_x Posted September 14, 2005 Share Posted September 14, 2005 mine stops at 7 and fuel cutoff is at 6800 rpms Link to comment Share on other sites More sharing options...
Speedy88 Posted September 14, 2005 Author Share Posted September 14, 2005 yeah but i dont get it it reads up to 3 so if i add another 200-300 it would still be in the 3s the tac never goes up to 6000.rpm Link to comment Share on other sites More sharing options...
..SSR.. Posted September 14, 2005 Share Posted September 14, 2005 Quit worrying about the tach and start worrying about what is wrong with your engine. Link to comment Share on other sites More sharing options...
XScarAudio Posted September 14, 2005 Share Posted September 14, 2005 yeah. I'd say take the cheaper advice given so far and revamp your ignition first Link to comment Share on other sites More sharing options...
x_outlaw_x Posted September 15, 2005 Share Posted September 15, 2005 yeah, i think my coil was about 55 dollars from advance plugs were about 1 each, distributor cap was 15 rotor was 7 Link to comment Share on other sites More sharing options...
