EkGsr Posted August 30, 2005 Share Posted August 30, 2005 I was wondering what i need to install ctr pistons into my gsr...or do they just bolt right up...besides rings and whatnot... thank you Link to comment Share on other sites More sharing options...
S14Silvia Posted August 30, 2005 Share Posted August 30, 2005 pistons, rings and you should have the block resleeved. its more work then just bolting them in. Link to comment Share on other sites More sharing options...
EkGsr Posted August 30, 2005 Author Share Posted August 30, 2005 even if the motor only has like 38xxx miles on it i should reselve it? Link to comment Share on other sites More sharing options...
..SSR.. Posted August 30, 2005 Share Posted August 30, 2005 Why would he resleeve to put in OEM pistons? You need to take the block and pistons in to a good machine shop, have them bore/hone it (get .5mm over pistons). Get some Hastings rings, ARP rod bolts, ARP headstuds, OEM headgasket, OEM IM/EX gaskets, OEM wristpins, ACL or OEM bearings, oil, coolant, another oil change after 15 minutes of idling. Save some money, buy some CP Pistons, and some light rods like the Crower Maxi-Lights. You'll have more power above 9,500 and it will be more responsive. You do know your CR will be really high with these in a C1 don't you? If you are on crap 91 octane, it is possible you might melt a piston. Link to comment Share on other sites More sharing options...
S14Silvia Posted August 30, 2005 Share Posted August 30, 2005 Why would he resleeve to put in OEM pistons? because thats the least that he SHOULD do. but i agree just cuz they are ctr doesnt make them that much better then aftermarket pistons. if it were me, i would look at endyne rollerwaves, but that might be a lil costly for this build. Endyne i believe the CR would be like 13.5:1 or somethin, there was a site that let you choose blocks, pistons, heads, and so on from different OEM honda parts and tell you the CR of said engine. the 13.5:1 is just a guess though oh yeah... Link to comment Share on other sites More sharing options...
EkGsr Posted August 30, 2005 Author Share Posted August 30, 2005 I thought the CP would be like 12.5....i only put 93 octane in my car....we dont even have 91 in florida..well some specialty gas stations do.. Link to comment Share on other sites More sharing options...
..SSR.. Posted August 30, 2005 Share Posted August 30, 2005 Reasons for sleeving: Reasons for sleeving: 1. Cracked sleeve 2. Already bored on stock sleeves and you are sentimental with your block 3. Bigger bore 4. Very high power on boost 5. Boost with a bad tuner (good tuners can tune to make 600whp+ on stock sleeves) Endyn pistons suck. CP's come in any CR you want. 8:1, 9:1, 10.5:1, 11:1, 11.5:1, 12.5:1, etc. You can run 12.5:1 on 93 with a good tuner, however, optimal dome height for flow and elevation would equal to about an 11.5:1 CR if you're close to seas level. CTR pistons are just normal Honda pistons that have a tall dome. CP's, Arias, Wiseco, etc are all far better. Link to comment Share on other sites More sharing options...
S14Silvia Posted August 30, 2005 Share Posted August 30, 2005 Endyn pistons suck. explain please, specifically since the rollerwaves are made by wiseco for endyne and then hand finished to customer spec.. Link to comment Share on other sites More sharing options...
EkGsr Posted August 30, 2005 Author Share Posted August 30, 2005 I wanna keep the CP kinda of low...around 11.5 to 12.0...because i want to eventually spray the car with like an 80 shot...I even thinking about just rebuilding the motor and sprayin on the stock CP, do you think it would be a little more reliable? THanks for your time guys... Link to comment Share on other sites More sharing options...
..SSR.. Posted August 30, 2005 Share Posted August 30, 2005 Their clearances are wack and so are the dome designs. Hand finished? I do that to all pistons that go in a customers engine I build. 11.5-12:1 is not low, that is high compression. Nitrous loves high compression. Nitrous hates stock rods and pistons. A built engine would be more reliable. 11.5:1 CP Pistons, RM rods, RM M21X cams/valvetrain, custom SMSP or RMF header for nitrous = golden. Link to comment Share on other sites More sharing options...
S14Silvia Posted August 30, 2005 Share Posted August 30, 2005 the clearances are "wack" because they provide pistons to people who actually make sure that the deck and valve clearances are correct when they build their engine. not everyone hand finishes pistons, this is done also to reduce friction within the engine, of course everyone should do this, but most don't. 11.5-12.5 is not low I agree, but I've seen these pistons do fine with turbo's and run well into the 9's so I dont see what the problem is. like I said earlier, I think they are great pistons, however, probably not for the budget most would put into a motor build, and definetly not for everybody. Link to comment Share on other sites More sharing options...
SexyH22 Posted August 30, 2005 Share Posted August 30, 2005 another reqason for sleeeving: blow engine, and cylinder walls are scarred to deep for a rehone. Link to comment Share on other sites More sharing options...
S14Silvia Posted August 30, 2005 Share Posted August 30, 2005 i would resleeve just to be on the safe side, although i guess its a bigger deal for b20's then it is for b18's Link to comment Share on other sites More sharing options...
..SSR.. Posted August 31, 2005 Share Posted August 31, 2005 Their clearances are wack because Endyn's theories are wack. He needs to get his head out of pushrod land and get into Honda land. How many people do you see running around with engines built by Endyn..... Not very many. I can count all the Endyn built engines I see on H-T on one hand. B20's don't need to be resleeved for low boost or high compression. Their sleeves are made of a stronger material than the B18. Link to comment Share on other sites More sharing options...
BigBirdSucks Posted August 31, 2005 Share Posted August 31, 2005 i would resleeve just to be on the safe side, although i guess its a bigger deal for b20's then it is for b18's my 84.5mm sleeves haven't given me a problem yet...and I've had my engine for over a year and a half.... Link to comment Share on other sites More sharing options...
S14Silvia Posted August 31, 2005 Share Posted August 31, 2005 the last i saw was that teh b20's were crackin stock sleeves under normal driving conditions in CRV's, this would lead me to believe that it should be resleaved for any type of build. but this might be the very first b20's? i dunno, maybe the problem has been fixed and all is well in b20 land. Link to comment Share on other sites More sharing options...
..SSR.. Posted August 31, 2005 Share Posted August 31, 2005 Yes, sleeves cracked. Why? Tuners suck. Look at all the B20/VTEC's with high compression and good tuning that are running fine, such as BBS's. Link to comment Share on other sites More sharing options...
S14Silvia Posted September 1, 2005 Share Posted September 1, 2005 these were stock b20's out of crv's.. maybe it was just early b20's i dunno.. all i'm sayin is if i'm putting that much into an engine ill take the extra security of knowing my block has been sleeved. Link to comment Share on other sites More sharing options...
..SSR.. Posted September 1, 2005 Share Posted September 1, 2005 All stock engines crack sleeves. Link to comment Share on other sites More sharing options...
