drummr6 Posted August 20, 2005 Share Posted August 20, 2005 I have a '93 Honda Civic 1.5 fuel injected with 5 speed. When I start the car it runs fine unless I try to drive it. As soon as I touch the gas pedal the check engine light comes on and it will not accelerate properly. Like as the RPM rises its being choked... However, if you let the engine reach operating temp. and then shut it off and restart, the light goes out and it runs fine with smooth acceleration. I checked for codes; there are none present. Any ideas??? thanks Link to comment Share on other sites More sharing options...
drummr6 Posted August 29, 2005 Author Share Posted August 29, 2005 nothin? Link to comment Share on other sites More sharing options...
donnie Posted August 29, 2005 Share Posted August 29, 2005 how many miles on it? Link to comment Share on other sites More sharing options...
XScarAudio Posted August 30, 2005 Share Posted August 30, 2005 give it a tune up first of all. second, run through some fuel injection cleaner...sounds like it is borderline running lean while warming up and you are getting alight b/c of that. Link to comment Share on other sites More sharing options...
MeAndMyHonda Posted September 1, 2005 Share Posted September 1, 2005 There's a cold start injector that helps put extra fuel into the engine when it runs cold... when the engine gets up to temp it shuts off... you might want to try looking at that... i don't know if your car has one or not but if it's fuel injected it should... if it's not working then it will cause it to run to lean when it's cold... Link to comment Share on other sites More sharing options...
..SSR.. Posted September 1, 2005 Share Posted September 1, 2005 Honda's don't have cold start injectors. Link to comment Share on other sites More sharing options...
drummr6 Posted September 1, 2005 Author Share Posted September 1, 2005 ok, well... now even when it gets to operating temp, it still runs like crap with the same problem with acceleration. fuel injector cleaner didnt do anything. could someone refer me to somewhere that shows how to check for codes? maybe i didn't do it right the first time Link to comment Share on other sites More sharing options...
..SSR.. Posted September 2, 2005 Share Posted September 2, 2005 c-speedracing.com has a how-to Link to comment Share on other sites More sharing options...
Humphries Posted September 2, 2005 Share Posted September 2, 2005 mother's mystery oil is the crap much better than just injector cleaner it gets gunk off the bottom of your gastank, unclogs everything and stabilizes everything liquid that has to do with your gas. Link to comment Share on other sites More sharing options...
