mediset Posted August 14, 2005 Share Posted August 14, 2005 Hi I am new to this forum. I own a 94,Civic,Manual TX. I hear a rattling noise from the front. Initially I thought that might be the license plate. But thats not it. The noise is heard when shifter is in neutral and when I slightly push the accelerator, and it doesnt come up if I rev up the engine more. It seems like to come in a narrow rpm range. Also the noise comes up when taking slow turns and usually in the second gear. Any suggestions. Link to comment Share on other sites More sharing options...
..SSR.. Posted August 14, 2005 Share Posted August 14, 2005 Turn car on and put in neutral but keep clutch depressed. Does it make the noise? Yes - You have a knock. No - Next question. Release clutch. Does it make the noise? Yes - Input shaft bearing (mainshaft bearing in case) is bad. No - No clue. Link to comment Share on other sites More sharing options...
mediset Posted August 15, 2005 Author Share Posted August 15, 2005 Thanks for the resp. There is a rattling noise sometimes when the clutch is depressed and the accelerator is pushed little. The same rattling noise comes up when in usually second gear and when the clutch is released. It sounds like a plate or sth vibrating. The noise though not much but is distinguishable. I read in few forums saying that it may be the heatshield. Any quick and easy suggested remedy for knock. Thanks again mediset Link to comment Share on other sites More sharing options...
..SSR.. Posted August 15, 2005 Share Posted August 15, 2005 If it's a knock you have to tear your engine down. Link to comment Share on other sites More sharing options...
donnie Posted August 15, 2005 Share Posted August 15, 2005 Any quick and easy suggested remedy for knock. umm get bomb and blow the engine up..the engine you got isnt worth the money to fix it... Link to comment Share on other sites More sharing options...
mediset Posted August 15, 2005 Author Share Posted August 15, 2005 :( I never thought that it will be that serious. Getting to know cars better. Link to comment Share on other sites More sharing options...
XScarAudio Posted August 16, 2005 Share Posted August 16, 2005 i doubt its knock. could be any number of a things that rattle at that rpm range. in my car, at about 4000 rpm in 5th gear i get a rattle in the shift linkage. get a friend to rev etc while you go listen. pinpoint where the sound comes from and use process of elimination. Link to comment Share on other sites More sharing options...
Fool50 Posted August 16, 2005 Share Posted August 16, 2005 hey dude check out the heat shields on your exhaust pipes i had the same problem for a while until i found out I had blown a weld on the heat shield and it was making a scraping noise. Link to comment Share on other sites More sharing options...
donnie Posted August 16, 2005 Share Posted August 16, 2005 this is true i got the same problim..my heat shield if frackED Link to comment Share on other sites More sharing options...
mediset Posted August 20, 2005 Author Share Posted August 20, 2005 Hey guys ...Just fixed the problem. As some of you suggested it was just a shield over the catalytic converter that got loose. Thank you all .... I am glad it wasnt a Knock Knock Link to comment Share on other sites More sharing options...
donnie Posted August 20, 2005 Share Posted August 20, 2005 good to hear Link to comment Share on other sites More sharing options...
