Entwined Posted September 28, 2008 Share Posted September 28, 2008 Sorry, don't know much about cars. Here is my problem: I have a 94 civic hatch cx, was running fine, still is but, when I rev at high rpms a puff of white smoke comes out my exhaust. On occasion my car will idle funny, like if its breathing hard it goes from 1000 rpms to 1500 up and down. I am not sure what exactly is the problem, I mean it drives fine so but, I would rather my car not explode on me because i disregarded this problem. Another note; it burns oil fairly quickly, so I added more now it is not smoking as much but still its a little irritating any sort of help would be great. Link to comment Share on other sites More sharing options...
mpearce1974 Posted September 28, 2008 Share Posted September 28, 2008 Sorry, don't know much about cars. Here is my problem: I have a 94 civic hatch cx, was running fine, still is but, when I rev at high rpms a puff of white smoke comes out my exhaust. On occasion my car will idle funny, like if its breathing hard it goes from 1000 rpms to 1500 up and down. I am not sure what exactly is the problem, I mean it drives fine so but, I would rather my car not explode on me because i disregarded this problem. Another note; it burns oil fairly quickly, so I added more now it is not smoking as much but still its a little irritating any sort of help would be great. Any water in oil?? White usually means bad head gasket and you are burning anti-freeze Link to comment Share on other sites More sharing options...
Entwined Posted September 28, 2008 Author Share Posted September 28, 2008 Any water in oil?? White usually means bad head gasket and you are burning anti-freeze Not sure what you mean by any water in oil..? Link to comment Share on other sites More sharing options...
cmgogo Posted September 28, 2008 Share Posted September 28, 2008 or vice versa, take off rad cap, put your finger in there, pull it out. is it clear, or is there a milky susbstance/film in your rad. also drain teh oil, is there any water in the oil? (not too hard) Link to comment Share on other sites More sharing options...
mpearce1974 Posted September 28, 2008 Share Posted September 28, 2008 or vice versa, take off rad cap, put your finger in there, pull it out. is it clear, or is there a milky susbstance/film in your rad. also drain teh oil, is there any water in the oil? (not too hard) Thanks forgot to say to check radiator too! Link to comment Share on other sites More sharing options...
Entwined Posted September 28, 2008 Author Share Posted September 28, 2008 Okay, Ill check that. Link to comment Share on other sites More sharing options...
MarineSniper217 Posted January 29, 2009 Share Posted January 29, 2009 I got kinda the same deal...milky coming from the tail pipe though! What could be wrong?! Link to comment Share on other sites More sharing options...
cranny Posted January 29, 2009 Share Posted January 29, 2009 both yas need hed gaskets , lol. 98% of the time in honda engines though , water and oil wont mix. Link to comment Share on other sites More sharing options...
MarineSniper217 Posted January 29, 2009 Share Posted January 29, 2009 I got a brand new mulitlayer steel headgasket in there... With ARP head studs holding it all together. Link to comment Share on other sites More sharing options...
Kastigir Posted January 29, 2009 Share Posted January 29, 2009 I got a brand new mulitlayer steel headgasket in there... With ARP head studs holding it all together. Did you follow the proper torquing procedure? Those multilayer steel are garbage. OEM is usually the way to go, unless you're running insane boost pressure. Link to comment Share on other sites More sharing options...
MarineSniper217 Posted January 30, 2009 Share Posted January 30, 2009 I thought multi layer was OEM...im starting a new post on gaskets to let him get his problem fixed. Link to comment Share on other sites More sharing options...
Kastigir Posted January 30, 2009 Share Posted January 30, 2009 I thought multi layer was OEM...im starting a new post on gaskets to let him get his problem fixed. OEM are graphite...not steel. Link to comment Share on other sites More sharing options...
