j2ejms93 Posted May 25, 2005 Share Posted May 25, 2005 ok i have a 1988 honda civic hatchback completely factory 5speed and all.ok i want to put the dohc zc motor into it the j-spec version of the 88-89 integra motor.what all would i have to get other than the motor and tranny? and would i be able to use a crx si wiring harness? Link to comment Share on other sites More sharing options...
EFHatchTuner Posted June 5, 2005 Share Posted June 5, 2005 I think you can use the single cam axles. Si harness is useable also. You may need motor mounts and an ECU. Link to comment Share on other sites More sharing options...
..SSR.. Posted June 12, 2005 Share Posted June 12, 2005 You need the complete swap (engine, axles, ECU, etc.). Before you put it in, put a Si (88-91) final drive into it. Link to comment Share on other sites More sharing options...
