bebiracer Posted April 28, 2005 Share Posted April 28, 2005 how much power gain if any is the difference between gsr and ls/vtec?? i got a stock ls block and a stock gsr head wat are the first couple of thing i should do to get a very big boost on power?? i have an aem cold air intake and a catback exhaust.. and suggestions? Link to comment Share on other sites More sharing options...
..SSR.. Posted April 28, 2005 Share Posted April 28, 2005 Tehy'll be about the same with LS/VTEC on top with torque. Link to comment Share on other sites More sharing options...
bebiracer Posted April 29, 2005 Author Share Posted April 29, 2005 so wat do u think is the first thing i should upgrade on my ls/vtec? and how much more power are we talkin about that itll give me ? Link to comment Share on other sites More sharing options...
HAN Posted April 30, 2005 Share Posted April 30, 2005 Link to comment Share on other sites More sharing options...
donnie Posted May 3, 2005 Share Posted May 3, 2005 max out your head... i got the same set up it gives you around 60 hourse...whats that lsvtec in? i got it in a little del sol. and what does it run in a 1/4 Link to comment Share on other sites More sharing options...
bebiracer Posted May 4, 2005 Author Share Posted May 4, 2005 well its in a 96 civic ex coupe.. it has all stock internals .. wats the best thing to upgrade on it first besides workin the ad out?? and is my faster now with the ls/vtec or was the gsr setup i had better?? oh and wats the compression on a ls block?? is it lower than the gsr? is it better to turbo? i know tis alot of questions but i know ssr or bigbird can answer them their like the people that know almost everything about hondas.. thanx if ya could help me out Link to comment Share on other sites More sharing options...
BigBirdSucks Posted May 4, 2005 Share Posted May 4, 2005 upgrade your rods and pistons. if something were to break in an engine, it's usually the rod that goes first. upgrade to stronger rods and higher compression pistons and you'll be fine. I can't answer all of your questions because there are many different factors. Link to comment Share on other sites More sharing options...
..SSR.. Posted May 4, 2005 Share Posted May 4, 2005 LS rods are good to 9,500. Rod bolts fail. You shouldn't be talking about "upgrading" an LS/VTEC, it should be done right the first time. Link to comment Share on other sites More sharing options...
BigBirdSucks Posted May 4, 2005 Share Posted May 4, 2005 LS rods are good to 9,500. Rod bolts fail. You shouldn't be talking about "upgrading" an LS/VTEC, it should be done right the first time. LS rods can handle some power, but if major power is a goal, the LS rods can't take it. plus, the motor is going to be apart anyway, so I'd upgrade damn near everything. Link to comment Share on other sites More sharing options...
..SSR.. Posted May 5, 2005 Share Posted May 5, 2005 If it is all-motor, the rods are fine. If it is turbo or nitrous, get some different rods. Link to comment Share on other sites More sharing options...
BigBirdSucks Posted May 5, 2005 Share Posted May 5, 2005 If it is all-motor, the rods are fine. If it is turbo or nitrous, get some different rods. if he's anything like me, he's subject to change his mind multiple times. of course, I'd buy a different block and built it for boost. Link to comment Share on other sites More sharing options...
..SSR.. Posted May 5, 2005 Share Posted May 5, 2005 if he's anything like me, he's subject to change his mind multiple times. of course, I'd buy a different block and built it for boost. Thats what you have to do. Otherwise CR and clearances will be off. Link to comment Share on other sites More sharing options...
bebiracer Posted May 5, 2005 Author Share Posted May 5, 2005 well i was thinking on goin turbo and nitrous lol so wat should i change just the rods?? or pistons as well?? Link to comment Share on other sites More sharing options...
..SSR.. Posted May 5, 2005 Share Posted May 5, 2005 Both. Link to comment Share on other sites More sharing options...
bebiracer Posted May 6, 2005 Author Share Posted May 6, 2005 how much boost can i run with stock internals??? Link to comment Share on other sites More sharing options...
redcoupe Posted May 12, 2005 Share Posted May 12, 2005 how much boost can i run with stock internals??? I wouldn't push it past 9, with a good tune. If you had a built LS/vtec you could run more, obviously. But if your car is OEM spec LS/Vtec then see my first answer. *NOTE* OEM Spec LS/Vtec meaning that everything is Honda, not aftermarket internals or bolts. LS rods are good to 9,500. Rod bolts fail. You shouldn't be talking about "upgrading" an LS/VTEC, it should be done right the first time. Well said. BTW, how reliable is your LS/Vtec? I have a friend with a built one, JDM b16 pistons, Eagle H-beam rods, balanced crank(not sure which one) with the basic bolt ons. And his runs like poop. It is ran off a OBD-0 Pr3, and was tuned with hondata. But on certain days, it doesn't want to run. Just wondering about this. Because his car has discouraged me from building a ls/vtec motor. Link to comment Share on other sites More sharing options...
BigBirdSucks Posted May 12, 2005 Share Posted May 12, 2005 my CR-VTEC runs fine, but it'll run better in about a week hopefully. Link to comment Share on other sites More sharing options...
91H22Accord Posted May 12, 2005 Share Posted May 12, 2005 dude i was just like you you should go on google and just do tons of research about the LSVTEC you will come to realize that it's not as easy as it sounds mines is going to run me about 2500 but ill be running 13's all motor on my 92 integra no NOS or Turbo Link to comment Share on other sites More sharing options...
redcoupe Posted May 12, 2005 Share Posted May 12, 2005 Clean head. Thats why I want a GSR block. Its easier. Link to comment Share on other sites More sharing options...
BadAssCivic Posted May 14, 2005 Share Posted May 14, 2005 " hello MR. ROD, how'd you get outta the block"? "well you see that hole in the side of the block"?, "Thats how" Tick, tick, tick, tick, tick, boom!!!! Dont do it please. They cant handle that much boost. Link to comment Share on other sites More sharing options...
BigBirdSucks Posted May 14, 2005 Share Posted May 14, 2005 " hello MR. ROD, how'd you get outta the block"? "well you see that hole in the side of the block"?, "Thats how" Tick, tick, tick, tick, tick, boom!!!! Dont do it please. They cant handle that much boost. feel free to tell that to my friend who had a 400whp LS-VTEC integra. upgrade the rods, rod bolts, and pistons, and you're golden. Link to comment Share on other sites More sharing options...
BadAssCivic Posted May 15, 2005 Share Posted May 15, 2005 feel free to tell that to my friend who had a 400whp LS-VTEC integra. upgrade the rods, rod bolts, and pistons, and you're golden. 400 to the wheels , yeah right! You are kidding right? What would that thing run then- ET? BTW, I meant stock stuff, your talking about rods and bolts and all. Link to comment Share on other sites More sharing options...
BigBirdSucks Posted May 15, 2005 Share Posted May 15, 2005 400 to the wheels , yeah right! You are kidding right? What would that thing run then- ET? BTW, I meant stock stuff, your talking about rods and bolts and all. no, I'm really not joking at all. stock sleeves even. all stock stuff? stock rod bolts would strip. Link to comment Share on other sites More sharing options...
91H22Accord Posted May 15, 2005 Share Posted May 15, 2005 B18B1 Block: Hot Tanked Decked 5/10000ths LS Crankshaft Main Caps LS Rods .50 overbore Integra Type R Pistons w/rings GSR HEAD: Skunk2 Valves 2 Ferrea Valves (because its just the way I got the head but it will not affect performance at all.) Skunk2 Retainers Bronnze lower and upper keepers New Honda Seals Skunk2 Springs 3 Angle valve job Milled head GSR cams Stock CamGears Vtec Solenoid Sandblasted There you go thatz what my lsvtec contains as now still need to spend about 2000 more since im buying new tranny and stage 3 clutch.....but i still need a vtec conversion kit..and some other miscellanious(<<not even close to spelling it right) stuff Link to comment Share on other sites More sharing options...
BigBirdSucks Posted May 16, 2005 Share Posted May 16, 2005 .50 overbore with stock ITR pistons? that doesn't work. Link to comment Share on other sites More sharing options...
