keffreg Posted April 23, 2005 Share Posted April 23, 2005 Was wondering if anyone could put a post on converting a DX instrument cluster to a EX/SI cluster do i need to do some wireing or will it hook right up Link to comment Share on other sites More sharing options...
..SSR.. Posted April 23, 2005 Share Posted April 23, 2005 Pull EX out, put Si in. Link to comment Share on other sites More sharing options...
Kastigir Posted April 24, 2005 Share Posted April 24, 2005 Tried this once, unfortunately it didn't work out. The wiring is different. Nothing worked right, even the speedo was off. Seat belt light became the brake light. Etc. Link to comment Share on other sites More sharing options...
..SSR.. Posted April 24, 2005 Share Posted April 24, 2005 That is not true. It is a complete plug and play. Link to comment Share on other sites More sharing options...
Kastigir Posted April 24, 2005 Share Posted April 24, 2005 That is not true. It is a complete plug and play. Well, all I can say, is that it didn't work that way for me. Everything bolted right in, but none of the gauges worked, and the warning lights were off. Link to comment Share on other sites More sharing options...
Hatch92 Posted April 29, 2005 Share Posted April 29, 2005 i swapped EX gauges into my cx and it works fine. no problems except the cruise light bcame my shift light..................oh well Link to comment Share on other sites More sharing options...
WickedCivic94 Posted May 6, 2005 Share Posted May 6, 2005 dx to si is different wiring . DX is not equipped with a tach therefor you will have to connect the tach like you would connect an autometer tach . Dx wiring is not plug and play straight over to si . Link to comment Share on other sites More sharing options...
Hatch92 Posted May 6, 2005 Share Posted May 6, 2005 my cx was plug and play with the EX/SI gauges. i swapped mine right into it same wires and everything. Link to comment Share on other sites More sharing options...
