djp73 Posted January 8, 2005 Share Posted January 8, 2005 through the firewall, im sure it isnt too hard to figure out just trying to get a jump on it as ill have a limited ammount of time to get it done thanks Link to comment Share on other sites More sharing options...
SexyH22 Posted January 8, 2005 Share Posted January 8, 2005 when i had my del sol, it had a hole in the firewall by the passenger side floorboard. pull out the mat, then pull out the carpeting and you should see it. it is easy access to the battery as well, then just route it under the carpet back to the trunk and mount your amp in the trunk. Link to comment Share on other sites More sharing options...
djp73 Posted January 8, 2005 Author Share Posted January 8, 2005 ok, figured there was something simple thanks Link to comment Share on other sites More sharing options...
SexyH22 Posted January 8, 2005 Share Posted January 8, 2005 Link to comment Share on other sites More sharing options...
djp73 Posted January 8, 2005 Author Share Posted January 8, 2005 i wonder if my box will fit lol Link to comment Share on other sites More sharing options...
xxscaxx Posted January 8, 2005 Share Posted January 8, 2005 just like sexyh22, i routed my amp power cable on the passanger side. if you look where your battery is, to the right a little further down is a rubber black cap. pull it off n then what i did was cut a small hole n ran the wire right through that. it comes out underneath by ur ecu and underneath the glove box. then i unsnapped the side moldings and ran it under there, and brought it out behind the passanger seat. hope this helps Link to comment Share on other sites More sharing options...
