92 16v Posted September 3, 2002 Share Posted September 3, 2002 My engine is a 92 16 valve with 170,000 miles on the clock. When I take the oil cap off I have pressure like the exhaust is coming out of the hole. Compression checked good. Took head off and everything looks fine.Engine runs great but some oil is coming out front crank seal probably from pressure. PCV is working fine. Anyone ever have this problem? It just started all of a sudden. Thanks for any ideas. Happy motoring. Link to comment Share on other sites More sharing options...
92 16v Posted November 5, 2002 Author Share Posted November 5, 2002 I am still working on this problem. I replaced the rings and the head gasket but I still have the same problem. Next step is to try to find someone at honda that has encountered this problem. Only other (pumps) in the block are the water pump and the oil pump. something is causing major crankcase pressure. Link to comment Share on other sites More sharing options...
optional187 Posted November 5, 2002 Share Posted November 5, 2002 thats wierd man, good luck. Link to comment Share on other sites More sharing options...
viperhack Posted November 18, 2002 Share Posted November 18, 2002 here are some ideas to start with: check all vaccum lines for cracks or disconnected replace pcv valve(its only like $2) and check pcv hoses for cracks, seperation, or debris inside such as dust and oil(clean inside of hose with pipe cleaner of appropriate size) replace crank seal replace valve seals(this should have been done a while ago anyway with that mileage) check EGR assembly for proper operation run a computer diagnostics recheck PCV assembly if none of these work, take it to an experienced Honda mechanic; dealers will rape you on labor and unneccesary parts, use it only as a last resort Link to comment Share on other sites More sharing options...
92 16v Posted November 30, 2002 Author Share Posted November 30, 2002 Thanks for the help everyone. Turns out that my problem is not a problem at all. Some engines are designed to be pressurized this way. Since I work mainly on domestic V8 engines I did not know this. If anyone reading this could do me a favor, the next time you have your car running, take off the oil cap and see if there is pressure coming out. So far I have checked a nissan 4 cyl and it also had the same condition. Thanks again and let me know what you find. Link to comment Share on other sites More sharing options...
optional187 Posted December 1, 2002 Share Posted December 1, 2002 so let me get this straight...you want me to take off my oil cap while the engine is running and see if there is pressure comming out? so...put my hand over the hole and see if pressure builds up? Link to comment Share on other sites More sharing options...
92 16v Posted December 1, 2002 Author Share Posted December 1, 2002 If you take the oil cap off you will hear the pressure coming out as well as feel it. You will not have oil spraying out though. It will be just as if your exhaust pipe was flowing into your engine block and out of the oil cap hole. I am guessing it has something to do with oiling the top end of the engine but I could be wrong. Link to comment Share on other sites More sharing options...
