hoverboy Posted October 17, 2004 Share Posted October 17, 2004 This is stupid, but, I can't figure out why my brake lights won't work. They worked fine yesterday. My passenger seatbelt is not working (automatic) and so I took most of the fuses out and tested them one by one to see if any were burnt out. None were (as far as I can tell!). Today I had my stepdad try to fix that seatbelt. The motor is busted so he basically just left it as it was but moved it to the closed (ie door shut) position. Anywho, tonight, with the head lights turned on, the tail lights are ON but they don't get brighter when I brake. Also, and I read that these two problems may be related, I can't shift from park to drive (or any other gear) after starting my car. I have to insert my key into the shift lock slot, put it in neutral, take the key out of the shift lock and start it, and then switch to drive. I saw on another post that I should check the brake fuse. But I DO NOT see anything that says "brakes"!!! Please help! :( My poor car..... Link to comment Share on other sites More sharing options...
Flipoid56 Posted October 17, 2004 Share Posted October 17, 2004 I dont think its a fuse problem.... My dad had a problem like this with his brake lights too and we went through all the fuses and relays about 100 times and still couldnt figure it out. After doing some research i found out that there is a switch that the brake pedal is connected to so that when you push down on the pedal your brake lights will light up. So it may be possible that your switch isnt working and youll need to get it replaced. Hope this helps -Flip Link to comment Share on other sites More sharing options...
hoverboy Posted October 17, 2004 Author Share Posted October 17, 2004 Thanks for the reply. Any idea where this switch is located? Link to comment Share on other sites More sharing options...
Flipoid56 Posted October 17, 2004 Share Posted October 17, 2004 im not exactly sure but i think it makes contact with the arm of the pedal so look around there and hopefully youll find it Link to comment Share on other sites More sharing options...
CRG7 Posted October 18, 2004 Share Posted October 18, 2004 it is a fuse. had the same thing happen a few years back with my crx when it was automatic. no brake lights, had to use key to move the shifter, no horn, blah blah blah. Link to comment Share on other sites More sharing options...
hoverboy Posted October 18, 2004 Author Share Posted October 18, 2004 hmm, thanks, I will check the fuses again tomorrow or the next day and see if that helps any. Link to comment Share on other sites More sharing options...
CRG7 Posted October 18, 2004 Share Posted October 18, 2004 did you check the fuses under the hood also? Link to comment Share on other sites More sharing options...
hoverboy Posted October 25, 2004 Author Share Posted October 25, 2004 yeah, I am pretty sure i messed up some stuff with those fuses, the cruise control wont activate now either! the horn also is silent....I am gonna have a friend that knows something about cars take a look at it, I will post again once that happens! Link to comment Share on other sites More sharing options...
hoverboy Posted November 4, 2004 Author Share Posted November 4, 2004 I started having what seemed like transmission problems the other day. I took it in to a shop. Seems like all the problems I am having has been traced back to the computer. Greeeat. Thanks for the help all. Link to comment Share on other sites More sharing options...
