SonicAftermath Posted October 13, 2004 Share Posted October 13, 2004 Hey, i'm havin a little problem with my 96 accord. Here's what it does It revs up to 2000 RPM then drops to 1250 RMP, then revs back up, and repeats that forever... as long as it's in park or nuetral. If i Put it in drive, it doesn't do it (as bad) also, while in Drive, it idles at 1050 RPM instead of 600-800 anyone else had this problem? Link to comment Share on other sites More sharing options...
coldee00 Posted October 24, 2004 Share Posted October 24, 2004 hey, i have the same problems with mine 90 honda accord. i am trying to fix it. i change the tranny and the timing belt but it still does the same thing. if i can't fix it, i just gonna get me a F20A. Its more powerful. Hope it doesn't idle again. Link to comment Share on other sites More sharing options...
awan565 Posted March 9, 2006 Share Posted March 9, 2006 disconect the egr valve pipe and check it again i hope it will help u Link to comment Share on other sites More sharing options...
phillyhonda800 Posted March 16, 2006 Share Posted March 16, 2006 sounds like the fast idle throttle. when defected or dirty it causes your engine to surge up and down. i once had this issue and it cost me about $140.00 for parts and labor at the dealership. good luck! Link to comment Share on other sites More sharing options...
Humphries Posted March 16, 2006 Share Posted March 16, 2006 clean everything.. get some marvel mystery oil and clean out the gas tank and injectors and then pour a quart in there next time you change your oil. mine was doing that when i hadnt driven it in about 4 months. After i cleaned it out, it worked great. Link to comment Share on other sites More sharing options...
Troubled1 Posted March 16, 2006 Share Posted March 16, 2006 My 90 Accord is doin the same thing, as far as the idle spikes I will take some of the ideas I got from all of you and try to get mine fixed, Thanx alien Link to comment Share on other sites More sharing options...
wingzerotype Posted March 21, 2006 Share Posted March 21, 2006 my '94 accord has a similar problem, but it only does that once in a while and it usually stops within 5 minutes. If it's not too serious of a problem maybe i'll just let it be... Link to comment Share on other sites More sharing options...
CleanGSR Posted March 21, 2006 Share Posted March 21, 2006 Wingzerotype - sounds like your problem is just your timing being off. Go somewhere and have your timing checked (or do it yourself if you can) Link to comment Share on other sites More sharing options...
InfinitePrelude Posted March 22, 2006 Share Posted March 22, 2006 when you push your car(s) does it make a ticking noise? Link to comment Share on other sites More sharing options...
Sol Survivor Posted March 23, 2006 Share Posted March 23, 2006 Vacuum lines. Link to comment Share on other sites More sharing options...
