brandonwiley Posted August 5, 2004 Share Posted August 5, 2004 aight i need some help. my drivers side front window will not work. i have tested the window motor and the switch, the motor was ok and the switch was bad so i got a new switch and it still will not work. has this happen to anyone or does anyone know how i can fix it? Link to comment Share on other sites More sharing options...
optional187 Posted August 5, 2004 Share Posted August 5, 2004 check fuses? Link to comment Share on other sites More sharing options...
tomegun Posted August 12, 2004 Share Posted August 12, 2004 I'm currently having this same problem. With mine, some days it will work some days it won't. I also replaced the switch and it didn't work. I question whether the motor is shot or not because it works sometimes. Could it be a connection? A wire? I would love to know the answer to this one. Link to comment Share on other sites More sharing options...
tomegun Posted September 2, 2004 Share Posted September 2, 2004 Can anyone chime in with experience with this? My window will not work for about two weeks then it will work for a day or two. The switch is like $100 and the motor is $130 on the internet. I would like to know what the likely cause of this problem is. I might have mentioned before, I got a switch from the dealer and it didn't fix the problem. I took it back pronto. I would really appreciate any help. Link to comment Share on other sites More sharing options...
flyboy2 Posted September 12, 2004 Share Posted September 12, 2004 I had the same problem with my window ( 93 accord ) it just did it once ? but i took it to someone to look at and i found out that i let some rain get in the window and caused it to not roll up it just froz ? hope this helps ? Link to comment Share on other sites More sharing options...
del slo team Posted October 17, 2004 Share Posted October 17, 2004 I also experience the same problems in my 94 Accord. If it makes a squealing sound then you have to adjust the track. It will give you more problems the higher the humidity. Link to comment Share on other sites More sharing options...
Lazrx Posted November 1, 2004 Share Posted November 1, 2004 This may help, as for the window not moving, a connection problem could be it, I read that in some Accord, the wire harness on the driver side door is different than others, on one of the styles honda used, the pins where the connector plugs into the switchbox on the door may come loose, so check that, also, it might be the window out of alignment or a seal might have come loose on the track down in the door. A quick tip that i'm sure everyone know, but just in case, use silicone lubricant (pep boys) with the red straw and shoot it down in the tracks of all the windows on both sides, this helps with the humidity and rainy day problems Hope it helps, Email with any improvement, I love a good challenge Lazrx1@comcast.net Link to comment Share on other sites More sharing options...
tomegun Posted November 2, 2004 Share Posted November 2, 2004 Does anyone know if there are instructions for replacing the window motor online? I got the motor and I will be changing it tomorrow. Link to comment Share on other sites More sharing options...
