DeeJayDelSol Posted January 25, 2004 Share Posted January 25, 2004 is it possible to modify the aux lights in order to install headlight bulbs? if so are there any complication that may occur in doing so? if not what are the best replacements, as in aftermarket fog lights, that would fit perfect in the holes in the front bumper? thanks! Link to comment Share on other sites More sharing options...
ktslil1 Posted January 25, 2004 Share Posted January 25, 2004 Okay del sols do not come with fog lights... Are you talking about the aux lights? I installed aftermarket fog lights along with my aux's and my reg head lights so my car actually has 3 pairs of lights on it... Link to comment Share on other sites More sharing options...
optional187 Posted January 25, 2004 Share Posted January 25, 2004 what bulbs go in those lights? just get different bulbs, i'm positive they make them. i'm sure you could modify them to take headlight bulbs, but you'd be going through a lot of trouble that probably won't be worth it. plus, you might run into some heat problems. Link to comment Share on other sites More sharing options...
BigBirdSucks Posted January 25, 2004 Share Posted January 25, 2004 if you want more lighting, the stock headlight housings can take 100 watt bulbs. I forgot what the wattage of the aux lights are, but if you go any higher, you'll risk melting your aux light housings. Link to comment Share on other sites More sharing options...
Gsj Posted January 25, 2004 Share Posted January 25, 2004 The aux bulbs are 21w(Ihad to change one last week). Here's a wee link for you. http://www.teamdelsol.com/technical/howto/...yes/default.asp I'm thinking 'bout doing this to my Sol in the future, but my next item on the list is a decent exhaust. Anyone know where to get one in Scotland? Link to comment Share on other sites More sharing options...
