carta79 Posted December 25, 2003 Share Posted December 25, 2003 Trouble code-----------------------Circuit or system Code 0------------------------------ Faulty ECM Code 1-------------------------------Oxygen Sensor Code 3-------------------------------Manifold Absolute Pressure switch Code 4-------------------------------Crankshaft Position sensor Code 6-------------------------------Engine Coolant Temperature sensor Code 7-------------------------------Throttle position sensor Code 8-------------------------------Top Dead Center position sensor Code 9------------------------------Cylinder position sensor Code 10-----------------------------Intake Air Temperature sensor Code 12-----------------------------EGR valve lift sensor Code 13-----------------------------Barometric Pressure sensor Code 14-----------------------------Idle Air Control valve Code 15-----------------------------Ignition output sensor Code 16-----------------------------Fuel Injector Code 17-----------------------------Vehicle speed sensor Code 20-----------------------------Electronic load detector Code 21-----------------------------Variable Valve Timing solenoid valve Code 22-----------------------------Variable Valve Timing pressure switch Code 30-----------------------------A/T FI signal A (automatic transaxle) Code 31-----------------------------A/T FI signal B (automatic transaxle) Code 41-----------------------------Oxygen sensor heater Code 43-----------------------------Fuel supply system Code 61-----------------------------Oxygen sensor Code 63-----------------------------Oxygen sensor Code 65-----------------------------Oxygen sensor Code 67-----------------------------Catalytic converter Code 70-----------------------------Automatic transaxle Codes 71 through 76-------------Cylinder missfire Code 80-----------------------------EGR system Code 86-----------------------------Engine Coolant Temperature sensor Code 92-----------------------------Evaporative emissions system The ECM is located under the dashboard, behind the carpet on the passenger side. The codes can be read by jumping the two-cavity diagnostic connector and reading the Check engine light on the instrument panel. If anybody needs help activating the trouble codes send me a PM. Link to comment Share on other sites More sharing options...
TLontheDL Posted December 25, 2003 Share Posted December 25, 2003 cool, thats some useful info i could have used when i had my previous car Link to comment Share on other sites More sharing options...
TYRONE Posted December 28, 2003 Share Posted December 28, 2003 this needs to become sticky......good stuff!! Link to comment Share on other sites More sharing options...
