DeeJayDelSol Posted December 3, 2003 Share Posted December 3, 2003 A friend of mine said that i should get some sway bars on my del sol. He had some on a car he used to have and he said it improved the stiffness and cornering alot. Since i did not see any post about sway bars i wanted to get your opinion on them. Also, which do you feel is a better strut, liquid or gas. Finally, what do you think i should do coilovers, sway bars or both. Link to comment Share on other sites More sharing options...
TLontheDL Posted December 3, 2003 Share Posted December 3, 2003 sway bars compliment whichever suspension set up you have. you'll only feel the effects of them if you try to run from cops or something.. if you have aftermarket tires and always make fast/tight turns just to feel the "nonrolling" of the car then be prepared to pay for new tires often. Link to comment Share on other sites More sharing options...
BuddySol Posted December 4, 2003 Share Posted December 4, 2003 Depending on your Sol, you might have some stock ones already on there. '94-'97 DOHC VTEC front: 24mm rear:15mm '93-'95 SI front: 21mm rear: none '96-'97 SI front: 22mm rear: 13mm '93-'95 S front: none rear: none '96-'97 S front: 21mm rear: none Got to be careful on the size of your bars, cause you can really change how the car drives. IMO, if your just doing some daily driving, and you don't have a VTEC, just get some VTEC bars, Civic Si bars, or Integra GS-R/Type R bars and you're good to go. Keep in mind, if you have an S or an early model Si, you'll need some LCAs off a VTEC Sol, 99-00 Civic Si or an Integra GS-R, Type R. The stock LCAs on the S and early model Si don't have the mounting points for a sway bar. Link to comment Share on other sites More sharing options...
DeeJayDelSol Posted December 4, 2003 Author Share Posted December 4, 2003 i have a 93 si model. I also know that i already have a sway bar in the front because i saw it while i was taking my tires off one day. but you also said that it will change the feel of the car alot, does it really make a big improvement on the handeling of the car? do you guys even recomend geting sway bars? And also what are LCAs? Link to comment Share on other sites More sharing options...
BuddySol Posted December 4, 2003 Share Posted December 4, 2003 Depending on the size of the bar up front and out back you can either have your car understeer, neutral, or oversteer. It all depends on how you drive, and how you like your car to feel/handle. It can be the difference between night and day or it could be very minimal. Usually, the first thing you should notice is that the car seems more stable when pulling through a turn, as well as lane changing. Stock, the Sol is so-so in handling. Throw on some bars and you got yourself one cornering monster. Progress had a Sol that was pulling 1.0g on the skidpad. LCAs are Lower Control Arms. Link to comment Share on other sites More sharing options...
DeeJayDelSol Posted December 5, 2003 Author Share Posted December 5, 2003 well i know i have a sway bar in the front because i have a 93 si, so the lower control arm should have a mounting piont for the sway bars right? the only problem i see is mounting the rear sway bar because my sol does not come with a mounting piont in the rear. Link to comment Share on other sites More sharing options...
BuddySol Posted December 5, 2003 Share Posted December 5, 2003 Hmmm. Yes the LCAs you might need to replace are the rear ones for the mounting points for a sway bar. Of course, some companies have made sway bars for cars without the usual mounting points. Link to comment Share on other sites More sharing options...
DeeJayDelSol Posted December 8, 2003 Author Share Posted December 8, 2003 Thanks alot buddysol, you were a big help. Now, does anybody know or have an opinion on which type of struts are better, gas filled or liquid filled? Link to comment Share on other sites More sharing options...
DeeJayDelSol Posted December 9, 2003 Author Share Posted December 9, 2003 I spoke to a friend of mine today, who is a mechanic. I spoke to him about changing my rear lower control arms in order to put some sway bars on. He told me that he could probally just drill a hole in the lower control arms that i have now in order to mount the sway bars. Do you guys think this is possible and would you recomend doing that instead of replacing the rear LCAs? Link to comment Share on other sites More sharing options...
JDM Jackass2 Posted December 18, 2003 Share Posted December 18, 2003 you can do that but i wouldn't reccommend it Link to comment Share on other sites More sharing options...
BigBirdSucks Posted December 25, 2003 Share Posted December 25, 2003 no, you can't do that. reason being is there's an actual place on the rear LCA for the sway bar to bolt up(see:small protrution on the LCA with hole drilled) Link to comment Share on other sites More sharing options...
DeeJayDelSol Posted December 26, 2003 Author Share Posted December 26, 2003 so, my 93 si already has hole where they can bolt on to? Link to comment Share on other sites More sharing options...
BigBirdSucks Posted December 27, 2003 Share Posted December 27, 2003 aftermarket bars for del Sols don't bolt to that part anyway. the aftermarket bars bolt to the bottom of the strut(where the strut bolts to the LCA. if your car has a rear sway bar stock, then it has the holes. if not, just get an aftermarket bar. Link to comment Share on other sites More sharing options...
DeeJayDelSol Posted January 1, 2004 Author Share Posted January 1, 2004 cool, thanks for the help! buddysol you said that i could get some sway bars from a civic si or an integra gsr. do you know which years would fit or would all years fit? Link to comment Share on other sites More sharing options...
BigBirdSucks Posted January 1, 2004 Share Posted January 1, 2004 do you have a factory rear sway bar? if not, neither of those will bolt up. Link to comment Share on other sites More sharing options...
DeeJayDelSol Posted January 2, 2004 Author Share Posted January 2, 2004 yeah i have a front factory sway bar. i think its a 21mm Link to comment Share on other sites More sharing options...
BigBirdSucks Posted January 2, 2004 Share Posted January 2, 2004 but not a rear. therefore, a stock rear sway bar won't bolt up to your car. Link to comment Share on other sites More sharing options...
DeeJayDelSol Posted January 2, 2004 Author Share Posted January 2, 2004 ok, thanks bigbird! do any of you have after market sway bars? if so what kind? Link to comment Share on other sites More sharing options...
