thesacrifice Posted November 21, 2003 Share Posted November 21, 2003 This problem used to only be once in a blue moon, but its happened two days in a row now. I will note that its been really cold..there's snow on the ground today. Anyways the problem only happens if I start the car for the first time in the day and drive a short distance , up the road to the gas station/post office box. Anyways after I turn off the car to fuel/check my po box and come back to the car it won't start. It cranks fine, the battery is definitely not dead. What's really weird is the second I open the hood and prop it up and leave it open and try to start the car it works. Any ideas? I know this is vague but what the hell? haha Link to comment Share on other sites More sharing options...
Drew Posted December 4, 2003 Share Posted December 4, 2003 Not exactly sure, but maybe you should let it fully warm up before shutting it off again... Link to comment Share on other sites More sharing options...
2.2-accord Posted December 30, 2003 Share Posted December 30, 2003 I had the same problem for a while. I found out it was the starter relay (i think that is what its called) . Once replaced i never had that problem again..... Link to comment Share on other sites More sharing options...
TYRONE Posted December 31, 2003 Share Posted December 31, 2003 when was the last time you changed your distributor? also check your battery cables!! Link to comment Share on other sites More sharing options...
